29 on WHAT tire?^
Toyota recommends 29 PSI and you cannot run 29 PSI on an E rated tire. I spoke to Discount tire who installed these E rated tires. They said to maintain at least 40 PSI on E rated tires.
E rated means it is a light truck tire with a max pressure is 80 PSI. The construction of the tire is rigid with many plies (I believe 10) are used to build the sidewall interlayers to hold heavy loads and keep 80 PSI pressures. These 10 ply sidewall interlayers should not flex like a C rated 6 ply tire. When they do, it tends to weaken the construction/interlayer design of the sidewall.
Almost guarantee they were talking about OEM or close to it.
If you actually want proper recommendations you need to go to who MAKES the tire and ask them directly.
And a stock vic PSIs can and usually are way different than say one of our trucks with bumpers/skids/sliders.
A couple of hundred extra pounds is going to raise that PSI number on regular "passenger" tires.
And you 100% CAN run Es at 29.
Should you for long periods? Probably not.
The truck is 53/47 in stock form. Gonna change when you start adding stuff to it.
These are on the "same" tire. Brand and model the same, just one is passenger and one is E. More data points for more informed choices.
Stock weight and tires.
With +800lbs
E rated stock weight.
+800lbs
From what I've found. E is overkill for almost everyone.
+ Extra sidewall protection. 10 ply
- Weight and more needed PSI to keep a good contact patch while on the highway.
But if you run the pressures too low you reduce the mileage they are supposed to be capable of by like 1/3 to 1/2.
C is kinda the sweet spot. 6 Ply (Or D for 8 Ply)
More sidewall protection than regular passenger but less than E.
Less weight than an E and less PSI for highway.
Softer ride than the E.
Passenger: Fine for stock. Usually 2 Ply
- Less sidewall protection.
+ Way less weight and PSI for highway.
Softest ride of the bunch.
But also the tendency to puncture sidewalls where you plan to wheel matters.
Dealing with a harsher ride vs not popping a tire off-roading.
If I get 33s for my trip this summer I will be trying to get Cs. Will post results/options in here or dedicated thread or my build thread if I do.
