Does he DD drive it?
Does he drive it to the trails?
-B-
I dunno anymore, it's been a few years. I know it was driven to the trails and back - I think he drives it from SoCal to Colorado every year for the XJ event out here as well as other BOTW events. It's probably not a DD (Richard is an older guy who is probably tired of dealing with any SFA DD)...but was built so it could be. There's really nothing to it - 6"-7" of lift and the suspension geometry is that of a near stock rig without killing clearance. Still a unibody and a sloppy platform vs. an 80, but biased to offroad use, very, very effective due to great clearance and light weight.
I daily drove mine, which had that much lift, but his build was smarter than mine. I had clearance robbing long arms (Y style radius arms) and so much arch to my leafs, vs. blocks and traction bar, that they didn't flex well.
It wasn't until I had the "big" leafs that I finally understood how an arched leaf spring binds by forcing the axle to twist (really the same issue as the 80 series front arms), but a flat spring moves the axle the same way fore/aft during compression and articulation, and therefore can provide a surprising amount of flex because you don't get bind from twisting, and those big rubber bushings can give a lot of flex (deflection and twist), way more than you'll get out of 80 series front arms. This issue is very similar to how our radius arms will bind more working on angle than if horizontal at ride height. These newer leaf designs can use 10 or more very thin leaves to balance load vs. performance and deliver a great ride, but they aren't cheap.
You can only draw so many parallels between an XJ and an 80. I think you could make it work well, but I'm hard pressed to find a reason why to bother to do anything nuts with an 80. It's not what they are good at. The key to me is to always find the point of diminishing returns, which is exactly the art of that yellow XJ. That is where the spend goes way, way up and the performance gains are minimal. Things like triangulated rear four links and busting your axles with tractor meats and hydraulic steering, blah blah blah.
The 80 may have the highest point of hitting diminishing return out there, because you can just put on a lift and 35's, gear it and go (with sliders). But it plateaus very quickly, like any SUV will. That's where the initial shock of the cost of 80 stuff fades...yea, you will spend big for sliders and lifts aren't cheap, but you get huge capability from that spend without forcing you to spend another dime (try that on any Jeep outside the Rubicon). So leafs make no sense unless you are already making no sense, in which case they can begin to make great sense
