Anyone in SD have a impact wrench I could use for 5 minutes?
San Diego
I want to install my panhards but there is one bolt on each rod that I cant get loose. i think I need to hit it with a impact wrench. Once they are broken loose i think I will be able tighten them back up enough to drive home and get them off again to install my panhards. I went to the local gas station and they wont touch it. I called ORW and they said they would charge me for the install. ugh. I cant wait to get a compressor.
I used a 1/2" drive breaker bar on mine. I had to lean on it pretty good. I think the bolt is either a 24mm or 27mm.
A breaker bar (24"±) is way stronger than an impact. I have both that you're welcome to, but I'm in Santee.
Problem is I cant get a breaker bar in there because the head will only fit on the bolt from the rear due to the of the pitman arm, and then coil is in the way of the bar. I guess I could take everything off to get to it. I should have done it when I had the coils out. Ugh.
From the pics in his build thread, it looks like he got it figured out.
