Anyone ever had this electrical issue?
Weatherford, OK
Appearently since I was recntly bragging about how all the guages in my rig were working perfectly, I cursed myself. Now They only work about half the time. It affects the oil pressure, temp, and fuel gueges only that I can tell. The really strange thing is that if they are working, and I turn on the blower, the guages and the blower quit working. Is this thing trying to drive me nuts, or is there an easy fix?
Check your ground for the instrument panel. Then clean your battery cables, both ends, and make sure you have metal-to-metal on the attach points.
Seriously, any time an electrical gremlin shows up on an FJ40, the very first thing to do is to try running a (temporary) ground strap.
HTH
Kirk
In my experience when things like this start happening the ground is usually the problem. That is assuming nothing is shorting, etc. I installed a fiberglass front end on a 40 int he 80's and very strange electrical things happened. When you pushed on the brakes the wipers started, turn on a turn signal and the headlights come on, etc. Turned out to be a bad ground and once correctled everything worked fine.
when your guages you metion go out is it like one at a time or all you mentioned at once?
If they do it would have to be something common. Another vote for checking ground.
Not a bad idea to remove the fuseblock and clean up the metal on the backside of it along with the metal where it mounts. Also, if your fuses are old try putting in all new ones, and clean and tighten each set of fuse holding clips.
As above, grounding is, or can be, a continuing problem. I like to add ground straps from frame to body, block to frame and body, and not rely on just one of each. You can't have too good of a connection to ground, and with the stiff way of these trucks along with the ways they are used any connection or ground can build up resistance through corrosion or looseness to the point where it causes enough of a voltage drop to interfere with any device's power requirement.
Anybody ever use the anti-corrosion paste that you can put on aluminum cables coming into the meter/breaker box of a house? Seams like it would be good for keeping connection and keeping the corrosion down to a minimum.
Just a thought, I'm probably going to give it a try on my rig once I get the starter back in it. It seemed like I always had a electrical gremlin last year. Looks like a couple of grounding straps are the way to go too.
Thanks for all the input. I figured it would almost have to be a grounding problem but wasn't sure where to start. I'll give these things a go and see what happens. Thanks again!
Hate to disagree, but it is probably not a ground problem because of the simple reason that the temp, fuel and oil pressure gauges have separate grounds. The chances of all of them being bad simultaneously is remote.
The blower symptom also indicates that the problem is a bad connection that is upstream (towards the battery +) from the blower and gauge circuits. When you turn the blower on, it sinks so much current that the voltage drops on everything that is down stream from the bad (high resistance) connection. Turn the igntion and blower on and start measureing voltages at the gauges and blower and start working back to the battery. (use one of the schematic diagrams in tech links to trace the circuits back through the fuse block, ignition switch, etc. ) When you find the point where the voltage jumps up to 12V, then the bad connection is between the last two measurement points.
Good luck.
I had a similar issue with my 55. Except it effected EVERYTHING that ran off electricity. Cutting blower on, hitting breaks, using signals would all cause things to go nuts. I cleaned, recleaned, added grounds to no avail. I even changed to a GM alternator, nadda. Finally, I replaced the fuse block with a blade style setup and voila! Problem fixed!
One note...
NEVER, NEVER, NEVER, NEVER, NEVER, NEVER, EVER, EVER remove the battery cable with the truck running and the Alt not working. BOOOOOOMB and you muffler is toast.
Chuck
