Anyone? - CLC Classifieds thread
Unreal deal.........
Custom 1975 Toyota FJ55 Built by "FC in Stockton", -- pre smog, titled and registered for the street
Full convertible conversion
Full roll cage (1 ¾ .120 DOM) integrated into frame, frame re-enforced, custom shock hoops, spare tire carrier, Trans and Transfer case skid plate
Front axle: D60, open, stock shafts, 4.56 gears, Disc brakes, Warn Hubs
Rear axle: GM 14b FF, Stock shafts, 4.56 gears, Detroit Locker, Disc brakes
Front suspension: 55 rear springs, FOA air bumps, Bilstein 5100 shocks, Scout power steering with PSC hydro assist, limiting strap
Rear suspension: 63" Chevy springs, FOA air bumps, Bilstein 5100 shocks, Ladder /traction bar, limiting strap
Running Gear: Chevy TPI 350 -- stock, SM465 trans, Atlas 5 to 1 transfer case -- twin stick, custom drive shafts
Wheels/Tires: Five (5) matching 39.5 IROKS on 17" Pro Comp steel wheels 8 on 6.5
Warn 8,000 lb winch
Dual battery setup -- Optima Red Top/Yellow Top
Tilt Steering column with GT Grant leather wrapped wheel
Custom aluminum dash with Autometer gauges
Hunsaker seats mounted to cage, fully recline with 5pt harness
Pyle Hydra Wake board speakers mounted to rollbar, Pyle Hydra 4 channel waterproof amplifier, 6x9 speakers in rear
On board air
Extra parts:
Dorman Pwr steering Pulley
Trick Flow TFX Electronic Fuel Pump
PSC Motorsports Power Steering Pump
ARP Belhousing Stud kit
Warn Locking Hub parts
Duralast Multi V Belts
Tantrum LED Strobe system
Timken Roller Bearings
Pyle 5 ¼ Dual Cone Water Proof Speakers
HELLA driving lights
Cabra 19DX 1V CB radio with 6' whip antennae
Hi Lift jack
Spare FJ55 grille
New FJ55 gas tank
Box of electrical parts
Box of misc spray paints, fluids and grease
Box of all sorts of misc screws, washers and nuts
Trail box with misc tools
Box of misc body parts
This is an estate sale the rig belonged to my nephew. This is a fully running/driving vehicle that needs minor TLC to complete:
On board air plumbed
Radio, speakers wired
CB wired, antennae mounted
Driver side floor board needs patching, patches included
Leak between trans and transfer case
Motor needs to be tuned and dialed in
We are asking $15,000 but are open to honest, sincere reasonable offers. I will not "take offers over the phone". My nephew had put tons of money and time into this rig and we want it to go to someone that can appreciate it and knows what it takes to build something like this. Thank You
Don PMed me 2 weeks ago and reminded me that I slobbed his knob for 6 months while he built this thing and I said to call me if he ever sold it.
I passed. I just don't want a crawler, but man-o-man, to own an FC187 creation.........
Sometimes you have to step back and look and say
"If I keep throwing money at this I will still have junk"
This tho.....
WOW!! just WOW!!
****SOLD****
I did some trading and ended up with these tires. They were a friend of mine's, and I've seen them firsthand hook up unlike any iRok. Kinda boggles my mind...
Anyway... they're bias-ply 37x14.5/15 iRoks with ~75% tread in the middle and the typical rounded outer lugs. The wheels are DIY beadlocks with new bolts (only a couple of rides on the bolts). The pattern is 6 on 5.5", but the center bore is too small for a Toyota hub. They could easily be opened up to work on Toyotas. They will clear Waggy and Chevy D44 hubs without modification.
Asking $800 for tires and wheels, or $600 for tires and $250 for wheels. Tires and wheels are in Hot Springs, Arkansas. Listed for more on CL because... well... I'm fairly certain I'll get lowballed either way on CL, so may as well start a little higher. I can already feel the "will you take $200 for tires and wheels?" texts coming... :popcorn:
http://littlerock.craigslist.org/pts/5158872281.html
Who's stable will it call home?
JTTMF'nT made the announcement. He's also the only one in CLC running a heavyweight trail rig whose wife does not have a trail buggy.
My money is on Mrs.JTTMF'nT.
Have a R151F Turbo 5-Speed out of an 86-87 truck for sale. I used it in my rock crawler for a few years before I parted out the truck. Time to move it on to someone else.
Will come with Shifter and complete from bellhousing to tailhousing. In good shape when parked. Will make sure it's good before it leaves.
Asking $450 plus shipping. Fastenal has been pretty consistent at $150 to ship something like this.
Located in Hot Springs, AR. PM or call / text - 501 two6two 80 18
I hope you are right Cam!
GttMFT!
