Anybody Use This Insulator?
A ha! Thanks for pointing this out.
Back in the '80's, I designed a carpet system using outdoor carpet and foam. Looked quite good and really quieted the beast down. This stuff might be even better, think I'll order a bunch and give it a try.
I cut insulation myself from the foil backed stuff available from Summit or JCWhitney. That allowed me to work higher up the firewall in the footwells. Noticeably quieter.
I used smaller pieces and glued them down with carpet tape, and then put on top an el cheapo outdoor carpet from the local hardware store.
Colorado Boy-74-FJ40 said:
Doesn't that trap moisture?
I'd be interested to know from those that have used this also. Guess you could Rhinoline/POR/LINEX before...?
already have
I sprayed Duraliner this summer. I live in a very rainy climate so trapped moisture is my enemy. I wondered if the noise would be reduced enough to consider the mat. Everything on the 40 is noisy, I would seriously doubt that the mat would reduce it that much.
