And this is a just a silly question... what size drill bit for an M8 x 1.25?
You'd want either an H (.266") sized drill bit, or a 6.8mm drill bit. Make sure to either get or make a bottoming tap. Good luck with it!
Brian
Bottoming tap? I just have the metric taps I always have had.
The small hole that is unthreaded is for the throttle pivot used on early F engine Cruisers and some forklifts.
Yes, it can be threaded, it is a pretty dead area of the block, above the oil gallery, below the water jacket...
Regular taps are tapered and won't cut threads all the way to the bottom of a blind hole, they're made for holes that go all the way through.
