Essentially the old part was a pair of O2 Sensors, the new part is simply the one with the longest pigtail of the two so it works in both spots. I just had an interesting issue getting through CO emissions with ours. Our outboard sensor had a bad heater, so I replaced it and ordered two. I was going to replace the inboard but per the FSM it was working and I could not get to the inboard sensor. We failed emissions several times.Thank you all. The part numbers worked. I ordered them. Coming tomorrow. I appreciate your help.
I know what you mean, the last time i did this job i ended up dropping the cats, along with the head pipes to get at the sensors, That was due to the fact that the nuts holding the sensors in place were so badly corroded there was almost nothing left of them.Getting the inboard sensor out was above my pay grade!
