So I decided to tackle the broken power antenna. It was not too difficult, but had its challenges. The motor can be accessed from the hole in the wheel well. First the fuel pump resistor must be removed, one screw.
The antenna motor can them be removed by unscrewing the silver collar that screws into the fender and the one screw holding the motor in place.
The motor can be pushed down, turned upside down, and pulled - maneuvered - out of the access hole in the fender.
There is not a lot of slack. The cover is removed by taking the 5 screws out from the corners, and the one from the center. Note - be careful not to loose the nut that is behind the screw in the center...as I did. Oh well.
This what it looks like on the inside. There is a black gooh that is between the 2 halves I think it is a water seal.
You will remove the cam in the center and this will expose the plastic track that goes up through the antenna. The track in mine was broken in the places inside the motor. Here is the cam.
