Another SM420 Q?-2F install
Montgomery Co. TEXAS
Website
missionsonwheels.org
Okay, going through Jim Van de Ven's tech article on the SM420 to 2F install, I need to know;
Can use my 4 speed flywheel and pressure plate (article wasn't sure)?
Also has anyone built there own input shaft sleeve? 1.5 inch x 18 gauge? Is it worth it do just buy one instead of fabbing it? Best source?
I've got a Centerforce clutch in it now, should I go with the 10.5 inch or 11 inch clutch disc?
Does it matter if I go back with a Centerforce disc or not?
yes you can
Best source is to get the AA adapter for $100
10.5"
probably
I used the 2F flywheel, but used my old F bellhousing so I could retain the old clutch hydraulics.
I bought my adapters from Extreme bends and was happy. I did end up using the pilot adapter listed in other threads here instead of the extreme bends piece.
I also used a GM centerforce clutch plate with my centerforce toyota pressure plate. Mine fit fine and did not have to shave any off. I would stay with centerforce if that is what you are running. 10.5" all the way.
Yes....Cooooool
Found this at Etreme Bends, 38 mm o.d., ~62 mm long
It should be possible to make this item from a standard piece of schedule 40 (? )pipe with an i.d. of approximately 1 3/8". The pipe will require being tapped onto the bearing retainer with a plastic-faced hammer on the SM420 and will be a snug fit.
66fj40 said:
I've got a Centerforce clutch in it now, should I go with the 10.5 inch or 11 inch clutch disc? Does it matter if I go back with a Centerforce disc or not?
10.5 inch Centerforce it is!
Thank You! Clutch ordered and pipe being cut and turned now!
why are you guys using an sm420 vs a 465? is it bc of the ratio difference or is it easier and cheaper to install?
For me it was the crawl ratio. I didn't want to change to 4.56 or 4.88 gears cuz I still like driving into town. I picked up my sm420 cheap :D . I have a couple of spares now, one good (and for sell soon) and one for parts.
RUSH55 said:
I used an 11" disk with my 4spd. pressure plate and flywheel, and used an angle-head grinder to take a little off form around the circumference, though I'm not really sure why. It seemed to me that the 11" would fit without any alterations.
My clutch guy called back after I posted and he couldn't find a 10.5 inch Centerforce so we ordered the 11 inch. Chef posted sometime back that the 11 inch will work fine and will "self clearance" after about 15 seconds of running. I may trim mine though, :princess: in guess.
I found that the Centerforce disk for the 4sp 2F had a center section with splines that were identical to the GM 11 inch. I couldn't tell any difference with a micrometer and they fit exactly the same on the GM input shaft. I suspect that Centerforce is using GM centers for their Toyota clutch disks. Maybe you don't need a new disk of you have a Centerforce.
66fj40 said:
One more question...I Promise!!
Do I need to use the 4 spd or 3 spd throw-out bearing for this project?
:beer:
Use the throw out bearing that is for the clutch assembly that you are using.
Three speed clutch-three speed bearing
Four speed clutch- four speed bearing
Good luck!
-Steve
Right on the money Pin_Head, no difference at all! Anyone need a Centerforce clutch disc :D
