Another Painless wiring thread
Kamloops, BC Canada
Website
www.shopraddcruisers.ca
I was given a harness to install, it sure is intimidating when you pull it out of the box.
The 1965 FJ40(best year of them all) has a minimal wiring harness and I suspect there will be a pile of unused wires.
I don't know about the Painless setup, but any wiring job is intimidating...
I priced paying someone else to rewire my Jeepster, then quickly decided to do it myself! A local outfit put together a setup based on my specs, and the era of the truck: basically a fuse block such as the Painless one, and a s***load of wires and connectors, etc.
I took a deep breath, and tore into it. The key is to be methodical, and take notes. You learn a hell of a lot in the process, too, about it all works, which is indispensable. I never had a problem after I did it, not sure I'd want to rewire a newer vehicle (mine was a '67).
Be extra careful with the connections. You can usually reuse your plastic connectors, just get new crimp junctions for them...
Complete instructions? Hopefully...
You just have to start, and actually do it. There is no other way. I was intimidated as hell when I had to rewire my 1974 FJ40 with the Painless, but it is fairly easy. The extra wires and circuits can be used for fog lights, and other random crap you might put on there. I left a couple circuits on with the wires zip tied up under the dash. You won't need a few, just snip them off but leave enough to zip tie under the dash, you never know when they'll come in handy! Good luck, we're here to answer any questions, we've been through it before!
I wouldn't pull the entire old harness out. The hazard and turn signal switches will not work properly unless you keep/re-make some of the OEM connections. (Painless uses GM philosophy - if that is not a contradiction), Toyota switches work differently.
i need to re-wire my 66 fj45lv which i am installing all the running gear, motor and tranny from my 78 fj55 into. what does everyone here recommend? use the original? rip it out and go with painless? or build my own. what is on the truck is very simple now. my mech. says we should just build our own using new wire and electrical tape etc. he is very confident. i am clueless admititedly.
I used a centech kit and it was very easy. It took a lot of time but was easy. It was made easier by the fact that I did a GM steering column conversion at the same time so all of those wires just plugged in. I also used a GM headlight switch with the cruiser knob on it. That made it quick.
I just got my weatherproof kit in from CCOT. So, all you guys sayin it's easy, what kinda stuff have you hooked up before tackling a full rewire job? I can hook up a basic stereo, add lights & a CB, but that's the extent of my experience. I noticed the Powerbraid wire mesh sample they included but it looks as if mud can seep thru the mesh & harden up. Anyone tried this stuff?
