Another (not so similar) DL vibration thread...
Highland, UT
Ever since putting the 4" lift on the 80, I've been experiencing some fairly strong vibes at both 40-45 mph, and when just applying/letting-off the throttle at highway speeds (65mph+). I have been driving it that way for several weeks, but finally got tired of it and started the front shaft/rear shaft dance to isolate the vibes. I finally narrowed it down to the rear shaft. I had tried to feel for loose u-joints before, but only recently (after isolating the vibes) did I finally get it to wiggle a bit for me. So I took it to Six States in Orem, UT today and had them diagnose it. Turns out the u-joints are still in good shape, it's loose splines that are causing the vibes. You could actually get it to rotate on the splines approx. 1-2mm with your hands, and could even get it to move the same amount horizontally. I was quoted about $350 to rebuild it (new splines, slip joint, dust boot, u-joints, balance, and paint).
I'm now wondering if this could be the source of other people's vibes who have replaced u-joints and still have some vibration, so I'm posting up as an FYI.
Regardless, I figured that for another $50 or so bucks I could get a good CV shaft from Slee, so I ordered one up. Jason at Six States thought this was the best solution also, and actually thought that Slee's price was a pretty good deal...better than he could do given the existing shaft condition. Of course, it was a good excuse to get some other "needs" from Slee.:D
Merry Christmas!
$350 is way to high a price.
You could buy a used drive shaft and then have it rebuilt and balanced for less than that.
Merry Christmas!
I've posted about this many times. The slip yoke is often over looked and at the age of these trucks the rear shaft is most likely shot for that reason.
I don't see why you need a DC shaft in the rear and I would have just called CDan and got a new factory one. The CV joint is not as reliable as a stock joint and that shaft will not give as good of service to you.
I'm surprised at Six States' response. For $350 they could have built you a brand new driveshaft with heavy duty tubing and skipped the CV, which is going to cost you a set of upper adjustable control arms to properly set the angle. That's a pretty expensive driveshaft.
I disagree somewhat on the CV shaft being inferior - I do agree that it is more complex, but the joints in the CV are running at half the angle each of a standard shaft, and the pinion end is running at zero degrees. Given that u-joint wear is directly correlated to operating angle, at a 4" lift a CV is certainly a reasonable choice. It's just the need for upper arms that burns you cost wise that would have had me building a new driveshaft.
In any case, good info since spline wear, u-joint wear, balance, and damage all all possible factors in these situations.
I've had trouble with two CV joints now and am going with a modified Tacoma shaft next. One thing I did not realize is that you should be using Moly Fortified grease in the centering section. I got that from posts of the factory manual on a Tacoma site. I bought a small grease gun just for this purpose.
Attention to greasing is much more critical on a CV shaft than a stock one. I personally would prefer to run a stock shaft for that reason alone if I could. You need to remember that you have centrifugal forces working to keep the end caps of the u-joint with grease which doesn't come into play with the centering section.
Grease that center section every oil change!
Rick,
Do you have pics of the Slee (spicer) front CV shaft? I read that there is a "hidden" spot (not a zirk) that also needs grease. I cannot find that on mine and I am getting a new "klunk" that wasn't there before the CV.
-B-
Thanks, I read that but it doesn't show where this hidden grease fitting is located. I know it is somewhere in the CV joint. I'm really not looking forward to 90 minutes of removing the drive shaft at every oil change.
-B-
I think Six States quote was high because the splines were worn, they would need to replace both the female and male splines, add a new dust boot, and while they were at it replace the ujoints at both ends. It was $315+tax just for those parts + labor. Add the CV and pricewise it put me in new CV shaft territory (~$500). I could have found an old shaft, had it rebuilt and probably got out the door for much less, but I'm too impatient for that so I just went with Slee. It arrives on Monday, I already have the upper adjusters, and now I have a trail spare.
It was curious to me that the splines would wear that way before the ujoints. It was easily noticeable that they were the cause of my vibes.
-B-
It's there, took me a while to find it the first time too. From the long side of the shaft, look for a small hole (concave) on the face of the ball housing inside of the CV. It requires the CV to be at an open angle and a needle tip to grease properly, and even then it's difficult without first removing it from the vehicle.
Rick,
-B-
Sorry I don't. Both my joints are something other than spicer but not Koyo. I'm looking forward to see what a Koyo joint looks like on Tuesday.
My X-cab Tacoma has a Koyo DC shaft on the rear and lubing is simple. Damn sure don't have to remove the driveshaft to lube it. :mad:
Are you putting this on the front or the rear?
-B-
-B-
I'm putting it on the front. It will get re-tubed and shortened.
Alvaro's post I believe is do to the fact that he has the IPOR skid plate. We talked about this when I was out in CA. The IPOR plate covers the joint and doesn't allow access to the zirks.
Part of the new drive shaft install is drilling access holes in the plate so I don't have to remove the DS to grease it.
I have an older DC shaft I got from SLee. It has a zerk point for the center section. It's much more convienient than the needle grease point on Alvaro's DC shaft. The joints themselves say "koyo" but I don't know who made the DC joint itself.
I think if you have the typical zirk that you find on the u-joints on the ceentering section then you have a Koyo unit. Since -B- has one on his Taco maybe he can add something to that.
That's exactly what it is. The DC joint itself has 3 zerks-one for each u-joint, and a deep 90 degree one that goes to the center section. It seems to work great-I grease every few months.
That's the typical setup for the center ball - a concave needle point fitting (I still have my needle point attachment from my Spicer DC days).
Can't see why you'd have the remove the shaft to get to it since the needle point can get in just about anywhere...those upper standard zerk fittings are typically in a much tighter space. I can't grease that joint on my stock driveshaft unless it is in the perfect position, and even then it is an extremely tight fit.
