Hi guys,,
Went to the garage to get into my 95 FZJ today. Its been parked in the garage since Feb, with a 1A Battery Tender Jr. (trickle with auto shutoff) hooked up. This truck sits regularly as I work rotation shifts and every time I park it, I do the trickle charger. NEver had a problem over the last few years of this.
I disconnected the charger and got in, turned the key and it cranked but had a clanging noise while it cranked. I turned it off immediately and tried again, this time, nothing, no crank.
I tried once or twice more and no crank but I finally got it to turn over and it started right up.
The Brake, AT Oil Temp and Oil Level Light were all lit, and it was on cold start idle (1200 ish)
I backed it out of the garage and I could hear a bunch of clicking from the dashboard and the lights were flickering like crazy, then and the lights disappeared and the clicking stopped. When I put it in neutral they came back on, and then drive, the lights went back off. I put it in park to shut the door and the lights came back on. Voltmeter looked in the normal position.
Drove it around the block, ran great, no lights on, voltmeter looked to be in the normal charging position.
Put about 10 miles on it, got home, put it in park, no lights, nice idle, figure it was good.
Shut the truck off, and tried to crank, nothing.
So far here's what I've done:
Removed battery cables. cleaned them and the posts.
Verified Battery is good (12.4 Volts)
Verified starter is good (pulled and tested at auto parts store)
Verified 12V at Starter
Verified the 2 Fusible Links (AKA Fat mans pants) in the fuse box were good
Verified the 15A fuse in the box is good
The Brake, AT, Oil Level lights all come on when the key is in the run position. When the truck is put in Reverse, Drive, 2 and Low, the lights turn off.
When I turn the key to 'start' in park and neutral, I dont do hear the starter switch under the dash click, but I dont hear a click under the hood, HOWEVER, I do hear a faint buzz/fan type noise, only makes it in Park and Neutral, not in any of the other gears. The clock and radio do go out when cranking.
I have no factory alarm.
Anyone have some help/advice?
I read some threads about the NSS but seeing as I have the 3 lights on the dash lit up, I'm going to assume that those are not an issue....
