Another heater hose ID post
Sacramento
I found a small coolant leak, as shown in the attached pic. My problem is I can’t seem to find the part number to this small 90 degree molded heater hose, attached to the firewall. My preference would be for OEM if possible. Any help would be appreciated.
Well darn. I really don’t want to go through the hassle of replacing that hard line. Does anyone know the hose size I need if I go with a formed aftermarket hose? And recommendations for brands?
That (rear) heater hose coming off the bottom of the T fitting is 1/2" (13mm) ID and not serviced by Toyota, it only comes with the complete rear heater pipe assembly.
In the past I've used a Toyota heater hose from a 1999-2003 100 Series that has a 90 degree section that can be cut to fit (87245-6A201 thanks to @cruiserdan)
The Gates hose listed above by TomH is a 90 degree formed hose, 1/2" ID and is a good option (less expensive also).
Only thing to watch out for when using a hose other than the original is the OD may be be different so the OEM clamp may not
fit correctly (too much or not enough squeeze).
FWIW
Appreciate the sage advice fellas. I’ll probably buy that OEM hose and cut to fit. Thx again!
