I really think that with one drawer it would be fine, but with two drawers it would be difficult. Copy and paste/invert your model to model a second drawer. I may be wrong, but it may prove awkward to access the mechanism...
Yes, I was referring to the PS, 3rd row, right behind the cupholders. You would have to remove panel to check the space. Your inverter isn't very large, it might even fit next to the subwoofer. An extension cord would be fine for the high voltage 120V. Chop the female end off and wire to your standard household outlet (consider outlet box).That's a good point. Btw, when you say the opposite side, do you mean move it to the passenger side (not sure where the rear AC unit is--I know the rear AC controls are on the drivers side)? or do you mean keep it on the drivers side as it is, but just move it to the other end of the box (i.e., towards the 2nd row seats)?
If it's the latter, any thoughts on how to access the plugs? extension cord?
Really like all aspects of what you've done. The CAD work is impressive. If you could print out full-size scale templates for both the wings and the anchor holes I'd be willing to shoot you a pay-pal to cover your time and postage. Would be a huge time saver to not have to re-invent that wheel.
Hard to tell how much space you have from the pic, but remember you need enough space on top of the latch for your finger. Also, because of your head height relative to the slide, you'll be reaching in blind. Just a thought...
Looking really good! I like the table top idea, just one suggestion- perhaps cut a semicircular cutout on the top center of the rear of the drawer so you can grab the top while the drawer is open. The accuride slides travel about 37" if I remember right, so they'll block access for your hand hold in the table top. Great fab work!
I like the idea of the inlaid cutting board. I'd dado cut both top and bottom of the board so that the table could be two-sided. Cutting board or table. Keeping the cutting board somewhat clean. Or is that what you already had in mind?
Funny, i was just thinking about adding a table to my ARB drawer in the same way. Except, allowing the table to be pulled out, without the drawer pulled out. That way, if you have items on the tailgate, you can pull the table without having to clear that portion of the tailgate in front of the drawer... well, nothing that is under 9" high.
Table positioned on the top is fine. Just need to leave a gap on the top of your drawer front so the table can slide over it while the drawer stays closed.
1407driver said:If you do attach a cutting board to one side, make sure to seal the wood well or it will warp like heck. I'm sure you already know that, though, by the looks of your woodworking skills!
Also, if you stick to your design perhaps a simple way of keeping the table from rattling would be a couple of rare earth magnets epoxied into the rear of the table and matching steel screws in the drawer box... Or a couple of rubber bumpers on the back of the drawer face to compress against the table... Just throwing stuff out there!
