Another deceleration noise...
blunt
More ambition than motivation
Downast Maine
I started to reply to the other post on this and thought my noise was different enough to start a new thread...and that way I don't hijack anyone's thread!
I have two issues going on and I am not sure if they are related. I have OME heavies front and rear with OME shocks/stabilizer and don't have any bumpers or skids to add additional weight (as recommended). I have the blue 3* castor correction bushings from Slee. I had the infamous GRRRR noise that occurred when I let off the gas pedal. I removed the front drive shaft and it got better but did not go away. The forward u-joint was bad (it did not have play when I grabbed it from under the vehicle but was binding when I moved it around after taking it off the vehicle. I can still hear some of the same type of GRRRR after the driveshaft was removed so that causes concern.
I also notice that my rig darts around on the road (may be from the 305/70/16 Swamper SSR's?), so I am going to jack it up and look for play in the bearings and other steering items as well as the pinion nut torque. I did find some play in the PS drag link end, so this may be the cause of the darting.
The bearing preload was recently adjusted by a shop and I am wondering if they got the correct amount.
If anyone has experienced this/these problems, please let me know where I should be looking. I have done some investigating but wanted to post before I started tearing things apart...
:cheers:
from my experience the front shaft will cause a Grr coming off throttle at highway speeds if a DC shaft should be used.
Don't over look the slip yoke in the rear drive shaft. Mine was bad and I help another member out with drive line issues by identifying his yoke as being bad also. The difference is that the rear tends to be a power on vibration as under load the axle tends to flex from the worn joint.
Heavies with no extra weight may have your angles off in the rear. If I take out all the weight mine will vibe on decel on the highway, and my rear springs are about equal to OME heavy unloaded in ride height (about 3/4" above OME medium).
You probably need a DC up front and are aligned for it with the blues, and in the rear drop to medium springs or get adjustable upper control arms to correct the angles.
Or you could fawk it all and pioneer a new 6" lift designed for 37's since you are going to need half the parts anyway to fix your driveline problems :flipoff2:
Caster
You say yu have caster correction bushes fitted. Have you had the vehicle on a wheel alignment machine to check the actual caster. just fitting the bushes will not guarantee a result. You must check that you got the amount of caster that you were seeking.
Not enough caster = darting and poor handling. Aso poor return to center of the steering wheel.
Cheers
Hedley
I'm running OME Heavies front and back as well, but with an ARB up front and Slee Sliders, and I needed more caster correction than the Blue bushings could give. I have the same suspension, but with slightly more weight, so you may be in the same realm I was. For the wandering and darting, get your caster checked at an alignment shop to see where you stand.
And as for the grrr.... I replaced all the u-joints in both drive shafts and it reduced it greatly for me. I still have a slight decel grr in the front that's completely gone when I pull the DS off. So, I'll get a DC shaft built when time and money allow (already have the Tacoma shaft).
Don't tempt me... :clap:
The rear u-joints were recently replaced. The noise I was referring to sounds like it is in the front. I have 170K on the rig and am unsure how much PM the PO did. It may be a good idea to get inside the axles for my own piece of mind and baseline the fluids while I'm at it.
Cheers
Hedley
The shop I went to told me that I was at 1* of caster after the blue bushings were installed. In hindsight, I should have gone straight to the castor plates and got all of the adjustable arms, etc...
Yup, one is on the low side and could be a little darty. Shouldn't be too bad tho.
And you statement is one that get's echo'd MANY MANY times on this board. The 2.5" lift on these is incredibly easy. After that you potentially have a few glitches that you run into.
Thats why I like Slee's approach. They completely minimize the chances for vibrations or things to go wrong. People will spend WELL over his kit price in time/money/running around/research to figure out that they should have just bought that or made it in the first place. ;p
If I were you, I'd sell the Blue caster bushings, get the plates (or some plates) and get a DC driveshaft and be happy. Your caster will probably be around 3ish range. Vibration free and no more dartyness.
As with many others, $ was a factor when I purchased the lift. I guess I will never learn, as I have started small on every rig I've had and spent twice as much $ to get to where I'm "happy"...
The lift height where I'd be happy is always at least 1" higher than the height it is today...it's a never-ending project. :bang:
Good news is, If you do the DC shaft and the Slee caster plates, you are good to 4~5" I"m at. 3 on my caster, so one more 1" of lift I'd be at 2. But I'm pretty happy at the 4" lift.
The most part that people don't want to spend on is the caster correction. You can always put a J spring up front and run the heavy rear. That will get you to easily clear 35's, make drop brakeline brackes and bumpstops and swaybar lowering blocks. Get the caster plates and DC shaft, call it good.
Some people will spend WELL over his kit price in time/money/running around/research to figure out that they should have just bought that or made it in the first place. ;p. Others realize that OME is not a kit beyond the medium kit height and design cost effective suspensions that maximize the underlying platform for 35" tires without the extra spend of a taller lift.
Fixed it for you :D
Fixed it for you :D Others realize that OME is not a kit beyond the medium kit height and design cost effective suspensions that maximize the underlying platform for 35" tires without the extra spend of a taller lift.
Slee is IMO, the only "FULL" kit out there.
Slee 4" = $2033 (weld in your own panhards)
FOR= $1,360
So you added a DC driveshaft, blue bushings, rear panhard adjustable. On the cheap thats still $300ish in parts. So you are looking at $1,600-$2000 depending on the DC shaft and panhard setup.
So I'm not sure where the extra spend of a taller lift comes in, but they seems comparable. I'm sure Mr. Slee would let you make your own without certain parts.
I"m not going to compare the rides or anything like that because thats just a whole nother thread.
