Alabama Cut & Turn
About 3 weeks ago, my brother and I did a cut & turn on our dad's '73 FJ40. It had a spring over and had some scary handling at high speed because the pinion was pointed up a little bit and had incorrect caster.
The first pic is the caster that it had. It was about 1/2 to 1 degree.
The 2nd pic is the axle with all the hardware cut off of it.
The 3rd pic is fitting the axle up under the springs, deciding what pinion angle we wanted, and welding the spring perches.
