ANOTHER Caster question
I have a bit of personal experience to add, if I may. I got the J springs and ended up with -3 of caster. I had no additional weight. It netted 4" of lift. I got the slee blues and it did not put my caster to appropriate spec, only got me to 0 or .5+. I then got the slee plates and swaybar drop blocks, and now I am at 2.5+ and driving much better. I still have some vibes, and will soon be getting either a tacoma dc shaft or a new shaft from slee, and other components that will come with that. Long and short, go with plates if you have more than 3" lift...
Cheers!
Joel
I've got DC shaft up front from Christo for that same reason(see my sig). Drop bracket is 3". After DC Shaft the Grrr noise was reduced significantly but did not completely go away. My guess is this noise is now coming from the rear. I Replaced the rear U-joints with new OEM joints a month ago. Didn't help much. I need to measure the hub to flare measurement and post back later. If I adjust my rear pinion by getting some upper adjustable control arms, would that make any difference?
I've setup and have help setup a bunch of trucks and not once seen a reason for those rear adj arms. Lets see where the hub/flare measurements are.
Cheers!
Joel
Sigh. Another thread focusing on caster in relation to vibrations rather than pinion angle, which is what determines how any style driveshaft will function. Caster follows pinion angle in alignment, it is not the other way around, unless your usage does not create misalignment vibration and the component damage that will accompany it.
I have the FOR springs. Hub to fender (no flares), my measurement is 23.75", so this is ~3.5" of lift. I have corrected my pinion for use of a DC shaft (rotated it down to create a ~0 degree axle end u-joint operating angle) with Slee blue bushings. With a modified Tacoma shaft, my front end is running perfectly.
You can't do this on paper and guarantee a result. You have to measure your actual u-joint angles and figure out how much correction you need. In my case, with OME CC bushings, I only had 2 degrees of operating angle on the axle end, so I expected the Slee blues to provide the full correction for a DC shaft, and they did.
A caster sweep cannot tell you this. Only measuring your u-joint angles can tell you how much pinion angle adjustment you need. If you go purely on caster, and happen to have had low caster stock and are at a 3" lift, you may overadjust for a DC shaft and then no driveshaft style will work without vibes. I may have had high stock caster and a lower stock pinion angle for some reason, which is why Slee blues worked for me. You can't know unless you measure.
I could clearly add an additional degree of caster by rotating slightly under the 0 degree angle (I am probably a hair over right now), but the truck is driving great and the Slee blue bushings have added a lot of firmness to the front end replacing the OME's. We'll see how they do over time in durability.
LT's disclaimer is related to only advising a method that brings caster back into spec. That's fine, I don't disagree and he states that clearly. Those adjustable plates are a great solution, too. The problem is when you already have OME bushings, and you are looking at $45/bushing for new OEM and then the plates vs. just going Slee blues - the latter is a lot less expensive, which is why I did it.
Bottom line: You can only correct for caster without vibes on your stock axle because of the great fortune of changing to a DC shaft on a full-time 4WD 80 happens to require a lowering of the pinion (very unusual due to the broken back design of the stock shaft). Therefore, your alignment measurement is not caster - it is properly setting the pinion for the DC shaft. We know that this has the desired effect in caster alignment on a typical lift designed for 35's. What that end number happens to be is irrelevant, because you can't adjust a DC shaft materially without causing vibrations, so caster is what it is once you correct for the DC.
If you have OEM rubber bushings in your arms, build or buy the DC shaft first and install it before installing LT's caster plates so that you drill those plates for proper pinion angle.
This all makes sense, but I went with plates after having slee blues because my steering was still darty. I did it for driveability first and foremost. I now need to check my pinion angle, as Nay says, to see what will be required to move to the DC shaft. I hope that a solution will be revealed once checking the pinion angle.
Joel
Here we go. No flares. These are (middle of the) hub to fender measurements.
Passenger Side:
Front = 23.12"; Rear = 25.12"
Note: Rear Longer J spring is on the Passenger side.
Driver Side:
Front = 22.5"; Rear = 24.5"
Note: Front Longer J spring is on the Driver side.
Thanks :cheers:
Passenger Side:
Driver Side:
Thanks :cheers:
looks like you need to swap the rear springs. Besides that the pinion angle should be fine. Have you pulled the front shaft and drove like that?
Yeah I have been thinking of swapping the rear springs. Can't get to it until I'm done with my yard work, wife's got me in bind :frown:. No, I had never driven with the front drive shaft off.
