Ok. I have read several posts on the brake warning light, and I have the following diagram. This makes complete sense to me, except in one specific circumstance. Let me ask the quesiton of what SHOULD happen, then someone can relate it ot hte diagram for me.
Assume I pull the emergency brake with my foot OFF the brake pedal - The e-brake switch closes, and the normally closed presusre switches apply ground and the dash light comes on. This is what I would expect.
However, if wired like it shows below if I pull the emergency brake and then step on the brake pedal it looks like the light would go OFF (assume the key is on). The e-brake switch would close, but the pressure created by stepping on the brake would open the pressure switch, therefore no ground.
I would think that the light would be on anytime the e-brake is pulled with the key on.????
It seems like this would be the case if the right hand wire from the e-brake switch ran directly to ground instead of to the pressure switches. Then the pressure switches would work in conjunction with the brake switch, but the e-brake would always override the circuit when it was pulled.
I don't know how it is SUPPOSED to behave so relating it to the diagram isn't easy.
