Another annoying lift thread
Columbia, SC
Ok guys, before I get flamed to pieces I promise I really did search, but there is not only a MASSIVE amount of information on the subject, there is contradicting info on the subject regarding what spring for what height based on accessories/armor/bumpers/cargo carried. I understand most of us use the heavy front with some kind of spacer and a medium rear. I am more concerned with the need for adj. panhards, control arms, and serious caster (castor?) correction.
My plan is to run an ARB front, badlands 12k winch, drawers in the back w/tools and recovery gear, a roof rack, and sliders. I know by using bolt on sliders I can't use Man-A-Fre's caster correction brackets included in the OME J-spring lift listed here : OLD MAN EMU/4+PLUS 80 SERIES 3-INCH SUSPENSION KIT - Man-A-Fre but I was more concerned with the need for panhards, DC driveshaft, and rear control arms. Basically I'm unsure if the amount of weight I'm running will be enough. To weigh it back down. I love the look of the 80's with a 4in lift and 35's, it looks perfect.
Too much information is daunting, but then again it's so much better than the alternative.
I think you can break it into a few schools of thought.
#1 keep it simple and cheap and go OME 2.5" lift
#2 Go for the 4" lift and prepared to struggle a bit. Here is where you want to copy your favorite trucks you see here on MUD and learn from other experiences. Strongly consider a prepackaged super complete kit from a well known vendor here-cheaper in the long run (Like Slee Offroad).
#3 The new kids on the block, i.e. ICON, AutoCraft au. and the like with progressive long travel springs and high end shocks.
Still, the biggest thing is FOLLOW WHAT THE EXPERIENCED PEOPLE HAVE DONE!
Good luck!
Well there is more than one way to achieve what your after and each truck responds a bit differently so while there is conflicting info, its not to say one is right and one is wrong.
If you havent purchased yet I would opt to get the spring you need vs the spacer on top from the start.
I would prefer castor correction brackets 1st and bushings second to the drop brackets. The brackets work fine at a cost of ground clearance and potential hang up spots. That same lift is avail at other vendors with different castor correction as well.
Id not be concerned about panhards at that height. Useful and correct but not detrimental without and could be added later
Id venture no rear control arms needed
DC shaft is a maybe but may not know till installed AND settled. Each truck is different. Then you have compound effect of mods. If you do longer rear lower control arms it may solve need for dc or vice versa. There are adj uppers that play a role too. So see how diff combos can net results for diff rigs?
Open the quote^^^^ responded in red to some questions directly.
The weight you mention should be enough to settle back down to a manageable height. What are you after? You say you love the "look" a 4" lift and 35s but you list a 3" lift and enough accessories to bring it down to 2" when done. Not a thing wrong with that. 2.5" lift and 35s rocks. Keeps geometry simple and cheaper to solve. Id ask yourself what you really need. If you really like/want a bigger look i wouldnt be opposed to considering a 2.5" to keep it simple and cheaper and 1" body lift. Lots of haters out there on the BL but id be comfortable with 1" and keeps installation simpler. It will be a grand cheaper than the full slee 4" which is an awesome kit. We just dont know your budget.
Next ? Are you going to drop 5-6 grand for all those mods at once ? If you buy the springs for that build but it doesnt happen for a few years you wont have the right setup initially or when done. Springs are cheap in this game and easy to swap/sell
I run slee 4" fronts and OME j in back and net 3" over stock height with the weight of the acc in my sig. standard full armor and acc. Runs 37s or 35s just fine.
Edit: Dogfish beat me with some great concise info there
I go with the Slee it's the most Comprehensive kit out there. It's very common to start basic & lower then start filling in to make it right and then just a little more lift & a little more you get it, save some time and money and skip all that and go fore a full 4" Slee lift.
There is a reason no other lift kit has 4+ plus Front control arm correction brackets, most people want more ground clearance when they buy a lift kit those drop down Bracket's are going to hang up on everything, My stock one do and I am running OME J looking to Move up to OME 5" comp's
Plan is to buy all accesories at once and take a week off to install all of it at once. From what I had read the J springs produced closer to 4-5" of lift, even though they are only listed as providing 3". Would bushings alone be enough to bring everything back to spec? Or should I budget in for plates as well?
Thanks for the clarification on not needing panhards and control arms. With the J springs. If I do need a DC shaft then it is the front one that I usually need correct? Tallons or however its spelled (the ebay seller) has gotten great reviews and has reasonable prices, and I'm not interested in piecing together a junkyard shaft.
As far as the approximate look I'm after is about this
Slee Kit includes the DC shaft and Plates or if you go the piece it together route Tom Wood's make a nice DC Drive Shaft
That does look like 4" and 35s.
Short answer is bushings will probably not be enough. Go right to plates. Cheap in the big scheme of things. May want to read up on "washer mod" if its within your abilities to cut and weld or pay to have it done.
The js will initially produce that much lift... especially in the rear without a bumper.... and a noticeable rake or stinkbig effect.
My first lift was js on all 4 corners with no armor with standard 2* bushings. This was before plates or 3* black bushings were on the market. It had zero vibes but that was due to not enough castor which created a vague wandering.
Added arb and and m12000 and brought front down to better angles but increased stinkbug
Added 4" front springs to level out and tht required plates to cure the wander that came back.
That may push you into DC territory. Mine has been good to me on orm shaft but each rig is different. If needed the tatton looks like a great option.
As mentioned the slee kit is a well engineered and thouroughly thought out, yet expensive kit. Worth it but i never had the cash to spring for it. You can ask christo to include plates or arms, whichever you wish ($1000 difference)
Now i did say panhard and control arms not needed but they are the little pieces that help fine tune a lift and everyones level of tolerance is different. Your axles will be slightly offset but i didnt worry as it polished one frame rail more than the other ar full stuff and im fine rattle canning the frame there twice a year. For some thats unacceptable but i never noticed ill handling effects.
The panhard off set is approx. .5" in rear & less in the front with a 3" to 4" lift.
When you make adjustment for ride height one must also think of full compresion & where that tire is in the fender well.
I made my adjustments with wheel spacers... 1" & 1.25" on short side.
Never thought of using wheel spacers to even it out, but honestly for it to be reliable for long road trips on the freeway and not have any worries about breakages I think I'm going to have to settle for heavy front and medium rear with 33s or 295s at most. 35s are going to require a regear (for my tastes) as I'm in a 3fe truck, and with a 2.5in lift and 33s or 295s all I have to worry about is new bushings, shocks and springs, from my understanding anyways. I may still regear to 4.56 if I go to 295s.
Would it be worthwhile to source the springs and bushings from say amazon or something and opt for better shocks? If so which ones? I'm familiar with the brands others are using (Fox, Icon, etc.) and I know shock preference is rather subjective but given my list of intended accessories which of those other brands would you guys suggest? Or are the OME shocks sufficient? The only trails nearby me are Gulches ORV park (I'm in Columbia,SC) so I'm not looking to tackle Moab-esque obstacles.
Sounds like reason has won out here. I really like the 295 route--plus 255 is the same diameter and will fit snug as a bug in the stock spare location (without hanging down ala "rubber skidplate")
Buy your springs from a good MUD vendor. I would recommend @cruiseroutfit, they can sell you the springs separately if you would like to experiment with shocks. By most accounts the OME shocks ride pretty stiff, so would probably be a good match to your intended weight, but like you say, ride is really a matter of preference more than what is "correct."
If you want a 4" lift, you'll probably end up getting a DC front shaft. To me, looking back now, it is a no-brainer ... the 4" Slee kit is the most "complete". Not to mention it contains high quality parts. Discuss with them on the phone about your weight possibilities and get their heavy progressive rear coils or medium coils.
The MAF brackets are a bit of an eyesore. I ran them for years and the handling of the vehicle was really good. However, they stuck down pretty far and just looked corny. I never hit them on a rock though. Ended up swapping to the axle plates.
edit......Just read your last post. If you're going to do a 2.5 OME style lift, go for it. I just installed one on my buddies DD. It looks great with 295's, no DC shaft or panhards needed. We did caster correction brackets and he loves the way it handles.
I am doing all my work at the Auto Craft shop on Ft Jackson so I have access to a press, that being said do the bushings usually come out easy? I had a Nissan Titan (complete and utter garbage, never buy one) that wouldn't give up the bushings out of it's lower control arms.
Have you looked at tuff dog suspension? @reevesci is carrying their stuff and is the route I am going to go...
Never even heard of them prior to this, I'm not that well versed in spring rates and such, what are the differences in them and Old Man Emu ?
As far as the TD springs, they are dual rate which is in my book are better than single rate coils. @LS1FJ40 has a set & likes them.
I am currently running dual rate coils & will never go back to single rate.
Just looked at the heavy load level lift from cruiser outfitters, with the 850J springs with the 863 rears, plates, shocks (L shocks for the front and regular for the rear), & steering stabilizer. With this setup I should still be good without driveshaft, panhards and all that right?
I've run OME stock height springs and their 2" (really more like 3ish) IIRC, it was a LONG time ago. I purchased a 2" Tough Dog lift with dual rate springs and 41mm foam cell shocks. It is the best setup I have run in an 80. I could not be happier. I've run it empty and was impressed and am currently loaded to the gills (I'm guessing approx 800lbs in gear) and it rides like a dream.
I highly recommend them. I've purchased a fair amount of stuff from @reevesci and am thoroughly impressed by the quality of stuff he builds and sells.
(Sliders, roof rack, vinyl flooring kit, and Tough Dog suspension is what I've purchased from him in the past 9 months).
You should be fine without the driveshaft and panhards. Thats a nice combo. Now be aware you may need new ujoints in your current shaft as they likely have 1/4 million miles in one position. They dont always like operating at a new and different angle. Buy oem.
As far as your shock and coil question ....
Support a vendor here for whatever your choice. And shocks can be 100 each or 600 each so some of these ?s depend on your pocket still
Id give Marshall (@Trollhole) at TrollHoleCruisers a call or go visit his shop in simsonville SC. I know he is an ironman dealer and may likely be able to order whatever setup you like. Plus local for customer service or if time gets tight install help as well
511 palmetto drive #10
Simsonville SC
864 414 0563
The bushings come out super easy..... when you drill out the rubber and use a sawzall to split the ring carefully not to score the ID of control arm
Pressing out..... not always so easy. Ive pressed a few out with without drama on a 12ton and I had a set that challenged a 45ton air over hydro making everyone clear the shop. Drill, cut, clean, press in new. Easy peasy.
