I have had a 60axle sitting in the side yard for quite a while. I was eventually going to put it into the 40. Well the Dusy was particullarly hard on my front axle this year so i am starting the swap early.
I have ran the stock front axle for many years. It has Lukes (4x4labs) highsteer and has always stayed good and tight. I started running 1.5" wheel spacers a few yeas ago and recently started running 38.5" sx's. I think the combination of the tires and wheel spacers is just to much for the studs.
To keep the same width i currently have with the spacer's i am going with the 60 housing. I will also intall a fifth stud (bolt) while i'm at it. I will not outboard the springs because i want to keep as much tire clearance as possible. I will instead use one of Dan's (RufStuff) perch's combined with a notch in the housing to get to the 27" perch width.
This is a link to Rustynailjustin's post on Pirate where he acomplished the same thing along with a axle flip. Very cool. Baja FJ45 (Buildup thread) - Page 5 - Pirate4x4.Com Bulletin Board
Anyway, on with some pics for a start.
