- Thread starter
- #21
Good ole #7Dang, that sucks!
What number cylinder is that?
I hear that. I'm slightly convinced that my excessive worrying actually willed it into reality.Dang this blows. The paranoia of this happening to me is what caused me to sell my 2013
If you end up having your engine repaired vs tossing another in, swap all four of your chain tensioners. I have about 6k on mine after the engine work and the idle sounds like a swiss watch with all the fresh timing components. Yes I have new heads and such but I'm pretty sure the tensioners made the biggest difference.I hear that. I'm slightly convinced that my excessive worrying actually willed it into reality.
Now that I'm getting it addressed, I'll at least have it behind me. Now I just gotta convince my wife that we'll be good on big repairs for a while...
Love this. Thank you.If you end up having your engine repaired vs tossing another in, swap all four of your chain tensioners. I have about 6k on mine after the engine work and the idle sounds like a swiss watch with all the fresh timing components. Yes I have new heads and such but I'm pretty sure the tensioners made the biggest difference.
There is a big head gasket/coolant thread where multiple users tested the pH of their coolant of varying ages. Basically none were acidic.How often were you changing coolant? Seeing as old coolant becomes acidic and eats the gaskets it would be wise to stay on top of this. 2011 with 231k miles and no coolant leaks.
I'll have to look for that thread. HG failure definitely isn't acidity alone but it is a big factor. I'd like to hear more from OP regarding if he is the original owner and the cooling system maintenance.There is a big head gasket/coolant thread where multiple users tested the pH of their coolant of varying ages. Basically none were acidic.
I’m not saying there isn’t a chemical incompatibility, but the data posted here suggests it isn’t an acidity thing alone.
Plus, I had my coolant being changed per Toyota's schedule didn’t prevent a failed HG in my case. No overheat events either.
There are many variables that can bring light to main causes. We're you the original owner and did you do the radiator replacement during your ownership? Did you often have your vehicle under heavy load or just leisure cruising?
New to reading on the HG stuff. Am I understanding correctly that all 2008-2014 models have a higher HG failure risk or is it commonly a 2013 thing?especially for the pre-2014 rigs built before the HG update
Aside from part number do we know what the update was? Metallurgy? Soft goods? Sealing surface area?I wasn't the original owner, but got the truck at 105 and the typical radiator crack was just starting to form, no leaks yet. I did the first coolant exchange with the radiator at that time. Second coolant exchange at 155, third with the new design radiator around 200. Slight misfire on cold start at 235k turned out to be a HG failure in the typical spot on the #8 cylinder.
During my ownership it never got hot, and given the service notes and condition when I got it I doubt it happened with the previous owner. I would periodically inspect the valley plate area with a borescope as best I could, not finding evidence of a leak nor any appreciable coolant loss. When I did the HG job there was very slight evidence of a valley plate leak but it was so minor that lost coolant must have been in the ounces over a period of years range so I wouldn't call it a contributing factor.
My use has been relatively light duty, very little towing, lots of highway miles, though I do live in central texas so the summers are pretty warm. PO was in Tennessee, It does look like they did some towing based on the condition of the hitch receiver, but I don't know what or how often. Either way their use stopped around 105k and the HG let go after another 130k.
My takeaway is whether or not it's coolant acidity as a root cause, following toyota's recommendation for coolant exchanges isn't frequent enough, especially for the pre-2014 rigs built before the HG update. Though I do seem to remember at least one 2014 with a good history losing a gasket. My advice to owners of basically any toyota is cut the recommended mileage intervals in half. I'm not certain even that is good enough for certain years. And if that's best practice, there are a whole lot of owners that it's too late to start now. They must be getting nervous reading these threads.
I only called out the acidity thing because this is a real issue and I want the best information getting out there. Ultimately the recommendation to change coolant often is wise, IMO, but until we see concrete proof that acidity is the root issue, I'd prefer to call it a chemical incompatibility. Either way, looks really bad for toyota.. on top of the problems with the V35A.
I have done multiple drain and fills of coolant even before 100k on my 2021. I will do a couple more at 100k. This is overkill imo and isn’t reasonable given scheduled maintenance intervals per the manual.
The update was likely higher performing layers of Viton and/or improved bonding to the stainless steel layer. Maybe Toyota just didn’t manufacture these failing gaskets with material that was up for the task?
According to Victor Reinz, two things will delaminate the Viton, acidic coolant and too much heat. Given that testing has yet to reveal acidic coolant, my vote is for heat. Toyota runs these things hotter for efficiency/emissions via the coolant jacket spacers. The spacers reduce coolant flow to the intake side of the cylinders, which appears to limit flow to the cross drilling coolant entry points. Given the location of those between cylinders, are certainly an area of elevated temps. Of course, the exit of the cross drillings is where the head gasket fails. It’s also quite narrow there, that gives the head gasket limited real estate to work with. The V35A engine is very generous in this location. It also has trimmed down coolant jacket spacers on the intake side, so flow is high and does not block cross drill flow. Too bad their bearings implode.
