- Thread starter
- #41
I don't know enough about the inner workings of the tranny/t-case to make anything more than a semi-edumuhcated guess...
You didn't hear the typical "marbles in the garbage disposal" from a diff blowing, or any other horrendous noises, other than the tapping noise from the bell housing that you mentioned. We've pretty much ruled out the differentials. With nothing else to go off of, and everything else apparently working as it should (as far as you can see, at least), I'd focus on the transmission. It rolls smoothly, you can't hear any other noises, and you have no gears regardless of the transfer case position or locker on/off. I'm going to guess that something sheared in the transmission or torque converter, which is giving you the physical disconnect that you're describing.
That doesn't explain the issue with the parking pawl and the AT/P light being on (this points to the t-case), but a noise from the bell housing and a failure somewhere in the t-case at the same time seems incredibly unlikely.
I'm confused now too, the more I think about it. Is there some kind of safety disconnect that puts the t-case in neutral due to a transmission failure? You did say that the cruise control module bounced the RPMs off of the rev limiter. Could the vehicle be stuck in some kind of limp mode due to a failure somewhere?
I dont think you're going to be able to figure this one out on the side of the road, unfortunately...![]()
I'm with ya brother and on the same page....
Have any of the previous documented transmission failures been accompanied by a CEL? My folks lost the trans in their 03 TL-S on Turkey Day and it was accompanied by an array of lights. If so, the absence of warning lights (other than the A/T P) may be a good sign of a lesser problem.
All the other threads that I read here on mud related to tranny failures did not mention anything about any CELs. I as well hope that the absence of lights means that that it is something other than the transmission. Even after restarting the truck several times it is completely content and happy as if there is no issue.
Can you get any trouble codes tomorrow?
When your wife was shifting, did you notice the control shaft lever moving?
No, I don't have the ability to pull codes tomorrow, unless someone knows someone else who will let another someone they don't even know barrow their reader for about an hour, haha...
You know, I remember checking the transmission control shaft lever linkage since that was one of the first things that came to my mind, but I honestly at this point can't remember if it was moving or not. Based on the fact that I moved on to checking other things, I am going to make relatively certain guess that it was moving as expected.
put it in gear, and check for movement. So based on it not holding in Park, and the whirring sound you heard when you put it in Park, there will be movement here.
... Just used for quick reference..
) that could ultimately cost the poor guy more $$ or even his life.
