Annoying Overheating!
Kennett Square, PA
Website
cruisin4parts.com
Ok, I've posted before and tried searching around but I can't find exactly what I'm looking for since I don't have that temp mod everyone brings up, I have a "stock" temp gauge..
I'll be driving for 10 minutes, how long it takes for the engine to warm up, then it starts to raise above the normal temp, and go up to the red, sit there for a bit then go back down. When it goes back down it goes past the normal temp, slightly below halfway, as if too cold. Then evens out and then spikes up and stays up there. Last time this happened, I had to stop the engine and get out and take a look, but no boiling in that container on the right side of the 3FE. Different than what happened last night my thermostat was sticking.
I'm thinking fan clutch or something, I've never replaced anything of that stuff, or know much about the cooling system.
One possibility is you may have a sticky thermostat, order an OEM thermostat and gaskets, replace the thermostat and flush the cooling system, refill with fresh coolant and distilled water, wile you are ordering parts look at your hoses, pay particular attension to all the heater and oil cooler lines,
On the 3FE be careful with the 4 bolt holes in the lower half of T-stat housing, it is easy to crack, make sure they are not full of sealant at the bottom and do not over tighten,
How quickly does to go to the red and then back down. If it is raising very quickly and then dropping quickly it could be a short...
I 2nd the advice to look at the guage, sounds like a faulty guage / wiring from what you are describing, usually things get hotter and hotter when there are major cooling problems, not up and down. I would look into a temporary install of another aftermarket temp guage, that way you know if it is the guage or an actual cooling problem before you start throwing too much time/money at it.
I don't see how it can overheat and then underheat in a matter of minutes. The stock gauge has a dead spot. I'm not sure exactly what it is, but let's say for arguments sake, it's 150-200 degrees. That means the engine is heating over 200, then immediately cooling off to under 150 then going back to somewhere around 180, all within a few minutes. I don't think that's likely.
If not a bad gauge or wiring, one possibilitiy might be air bubble that is affecting the sensor readings. First thing I'd check is the most obvious. Wiring connector to the sensor. Then the wiring, then maybe trying bleeding any air out of the system.
You have been having cooling system issues since the end of August when you first posted. This is now your 3rd thread regarding your cooling system. In each of the previous threads you were given sage advise from myself as well as many others on this forum.
Before we go down this road again, let's take a stroll down memory lane together:
https://forum.ih8mud.com/80-series-tech/234620-overheat-while-engine-off.html
https://forum.ih8mud.com/80-series-tech/228163-92-overheated-today.html
I see from your first post on this latest thread that you have not replaced your fan clutch or thermostat and don't know much about the cooling system.
Dude...c'mon. I'm really trying hard to help you out, but gimme a break. Do something.
