I have two Rockford-Fosgate amps in my truck. One under each front seat. Yes, the rear heater unit has been removed. This was all done by the previous owner so I don't know the model etc.
Here is a picture of the one on the passenger side.
and in case it gives you any ideas, there are also custom speaker panels on the doors. Covered in leather that is a nice match to the factory interior. Overall the PO did a very nice job on the audio setup, although I've owned it for almost 8 years now and it's need of a little R&R.
IMHO Unfortunately the PO did a couple of serious mistakes:
1) Unless this PO had his ears in the knees, tweeter position is no good.
My sugestion should be between the door handle and the door lock, and if you paint the grill with the same upholstery color, it will be concealed and you will have the tweeters closer to the ears.
2) Power amps under the driver and passenger seat are a waste of space, it's for things that you want to keep handy like a machete, a mini shovel or a pack of condom
Seriously that should be the last place to put an amp since they will get wet if you cross deep water and your engine shut off. Toyota engineers located your engine/transmission ECU way higher for a reason.
Best place is inside the rear quarter and as up as possible.
Since you are limited to 4" speaker size on the rear doors (not on my case since I installed 6 1/2" speakers on it with spacers) and their highs are dampened by the passengers tighs, it doesn't make any sense to use a high power amp to drive them.
I got a great sound on mine with the non OEM head unit enclosed amp adjusting it's own crossover with a 125 HZ low cut-off frequency to the 4doors and the head unit sub ouput are directed to my rear quarter concealed 10" subwoofer drived by a 120 W RMS mono amp also concealed in the rear quarter.
Pros: concealed installation, no space wasted, lower chance to damage equipment from water, cheaper if you already replaced the head unit because you only need a small but powerfull subwoofer amp since bass is were more juice is needed, of course you need to replace the OEM´s for very efficient speakers in all 4 doors which require less watts from the head unit to produce a decent sound.
Cons: harder to install, less bass ump if you plan to attend a sound contest
