- Joined
- Jan 6, 2003
- Threads
- 64
- Messages
- 1,205
John Smith said:Unless someone can find something documented from an authority on brakes that says it is unsafe I will continue to run them.
If it works, that's great. Nobody is saying it won't work, I actually think it'll work fine, and you probably won't have any problem with it for as long as you own the car. I don't know if you'll find an authority who will say it's unsafe, but I doubt anybody would actually recommend connecting two lines together instead of using a single hose. Theoretically, you can connect 10 hoses from the MC and eliminate the hardline entirely. Can it be done? Yes. Would I do it? No. It's an extreme case I know, but a lot of things "work", it's just where would you personally draw the line between safe and unsafe. Since brakes are THE single most important part of your vehicle, i tend to be very conservative in this department.
The question in this particular case is, why would you want to do it if you have a choice? Is it to save money? Do you just have extra stock length hoses laying around and want to use them? Is it because you have special fittings, and that's the only way of doing it? I'm trying hard to think of a good reason, and aside from an emergency repair, I can't really think of one. You don't really save much money, and either way you still have to get under the car to disconnect the brake hose and rebleed the brakes, so it's not any easier doing it this way. If i were to try and save money or time, I think I would find another place to cut corners.
3jvj,
I don't think you'll see a pressure drop unless you keep the pedal stroke the same. The swelling of the hose will just require more fluid to build up the same amount of pressure. I really don't know how noticable it would be, cuz we're talking some really minor changes.
