Always On ABS and Center Diff (Flickering) Light
Show Low AZ
What I have - 96 TLC FZJ80, Factory Lockers, and 7PIN Mod CDiff Switch
History -
CDiff would not engage in 4L
I recently replaced the CDiff switch and it started to work properly when in 4L, disengage in 4H
I installed the CDiff Switch but didn't do the 7PIN Mod
Drove the TLC for <500 Miles without issue, until the issue stated below started this week.
** Keep in mind Flickering and Flashing are not the same, this issues is Flickering **
Issue -
While driving the ABS / CDiff lights came on with the CDff light flickering
I pulled over, turned off the TLC, restarted but had the same reuslts
I drove it home <5 Miles, no wheels chirping and it didn't seem like the CDff was engaged
While driving the CDiff Light will flicker sometimes going to solid
ABS Light will come on and off but not flicker
What I've done in this Order -
Removed the connector to the CDiff Switch and turned on the TLC - No change
Short the CDiff Switch Connector, try in 4H and 4L, power on / off, backup, go forward - No Change
Complete the 7PIN Mod for CDiff, turn on TLC, try in 4H and 4L with/without the CDiff Switch enabled, power on / off, backup, go forward - No Change
Drive it in Figure 8's in 4L on dirt - No Change
Results -
So far not matter what I've tried I still get the same result -- ABS and CDff Light On with a little flicker
Next Steps -
I'm thinking maybe this is a short due to the fact that I've disconnect the CDiff Switch and the lights still come on.
Anyone have any other suggestions?
If I'm reading this right, it sounds like an issue I had last with with my transfer indicator switch that is located on top of the transfer case.
Check this: https://forum.ih8mud.com/threads/center-differential-lock-transfer-indicator-switch-problem.498372/
I did the CDL switch mod in my '94 FZJ80 and had to replace the transfer indicator switch. Once I replaced that, my Diff and ABS lights stayed on permanently. I ended up having a friend press the CDL switch while I plugged in and unplugged the indicator switch while it was out of the transfer case. I screwed it back into the transfer case then everything worked perfectly. For now, that is. Wondering if you have a something loose on the transfer indicator switch?
I have a similar problem with mine after installing the CDL factory switch. Things worked great for several cycles, but now the ABS light will not go off. I have done zero to research the fix, as it was low on the list compared to other things I needed to get done in prep for a recent trip. I'm sure it is a fairly common problem.
Thanks for the post but it didn't seem like the same issue I'm having.
The CDiff light is now solid, however I notice it flicker when going over bumps, so it seems to me to be a loose connector.
So I put the wife in the drivers seat, turned on the TLC, and started moving some wires.
All appeared to be well connected and as I moved them around the CDiff light remained solid.
However, I found an area where the speed sensor had some black tape on around the wires
It looks like someone at one time had placed a tap on all three wires, as I was taking off the tape I believe to of the wires touched, as now I have no speedometer.
I wasn't sure if there is a blown fuse or a way to reset the control unit for the speedometer, as I can't seem to find much on this, but as of now I have the Cdiff / ABS Light on and no speedometer. :bang:
Any help or suggestions is most appreciated.
Did you properly re-wrap the wires that were taped?
Thanks for the reply. Yes I did re-tape them properly, however long term fix I'll be using heat shrink to repair the wires.
Current status is the same -- no Speed-O and Diff Lock / ABS Lights are still on :(
You probably already know this, but just to be sure it's obvious... the ABS computer turns ABS off when it *thinks* CDL is engaged, whether it is or not... so the ABS flickering or going on/off is likely just a bi-product of the CDL problem.
When the CDL light is on solid, are you able to then stick the truck up on jackstands (the whole rear or the whole front) and confirm if it is ACTUALLY engaged or not?
Confirmed - When operating normally (4H) the CDL is NOT locking its only an light issue.
I am able to engage the CDiff when in 4L and you can feel a difference and it properly disengages
Initially my TLC would start with neither light (ABS or CDiff Lock) on.
As I started to drive it the CDiff Light would start to flicker and eventually ABS would go solid
Currently the ABS and CDiff lights are on at startup and the CDiff flickers occasionally
Not quite sure where to go with this one, any suggestions are most appreciated!
Transfer case position switch sounds right to me. It's not a difficult thing to fix either. If the switch is bad or has a short it will tell the dash lights to turn on if it thinks you're in 4wd Low. Those are the two lights that come on when you shift to 4L. Doesn't mean you're in 4L, just means the switch is saying you are.
Thanks for the rely around the CDiff.
Where is the "Transfer case position switch" located?
I've recently replaced a switch that if you were looking down on the CDiff it would be located on top and at the 1 o'clock position.
Is this the same switch you are referring too?
Clean all you connections on the transfer case then use dielectric grease in it and reconnect. This will also help with continuity.
Your rig may of not had the 4low exercised very much and it may be sticking as well
Just some thoughts.
Thanks I'll give that a go and post backup. I should be able to get into it this weekend.
-- Solved --
This issue was resolved thanks to Murf and Abe at Camelback Toyota!
Turns out the wiring harness supporting the tranny and transfer case had multiple issues, mainly due to the previous owner putting wire taps on it. Abe was able to rewire these harness and all the issues went away.
Thank you for all your comments...
hey @mattman555 where were the issues with the wiring? I am having the same issue as you, and I have replaced all switches on the transfer case.
Could you give me a area too look? Did you have to remove anything to get to it?
Thanks
-- Solved --
Yea, don't like using wire taps unless absolutely necessary as a last resort.
Having the same issue right now, CDL flickering and ABS stays solid. While I drive (4H) both lights go on and off and the CDL flicker when I go over a bump. I need help I have a +2000 Miles road trip plan in two weeks.
Thanks
Replaced all switch sensors ( L4, CDL, NSS, ) and nothing I'm still getting the ABS and CDl light on when I'm on H4 and it goes on and off while I drive.
When I press the CDL switch I do not hear the "click" on the passenger side so I'm thinking it is not engaging, so is it possible it could be a relay?? If so, which one/s should I start checking first??
Thanks in advance
Cheers
I would start checking the wiring to the CDL sensor for shorts. The ABS lamp goes on when the CDL indicates locked. If that happens over ~33 MPH the ABS lamp stays on until the ignition is switched off.
