Aluminum vs. Copper Core
Salty City
Ran a search on this topic. Found only one post (by Fman) who reported copper vs AL numbers. He noticed about a 15degree drop after installing the AL unit on a SBC conversion. But, he did not describe the number of rows the copper unit had and he used an electric fan.
Specific question: has anyone found the same increased cooling efficiency when switching to an AL unit under the following conditions. Small block (5.3) Vortec, old radiator = 4-row copper and using the stock Vortec fan and a shroud. The 40 will be mostly a DD with an occasional easy trail at Mobe.
I've been talking to the guy doing my conversion and he thinks the stock, rebuilt 3-row with mechanical fan and shroud should cool the Vortec. I'd like to believe him, but am a bit concerned after reading the high temps reported in some of the posts I found with the search.
A stock Toyota FOUR core radiator should be able to keep up, but I would not mess with installing a three-core....or having one re-cored.
You can get a new brass four core online for under 200.00us.
Good luck!
-Steve
It's a scientific fact that aluminum dissipates heat better than the factory offering or at least that's what I read on the intardweb. That bein sed, I run an alum. rad 22" X 19" I got off Ebay for under $170.00. Fits great with minor trimming of the shroud & rad frame.
Good luck!
-Steve
I personnaly would not recommend running a LC radiator with any V8. I went through many trial and error periods with a 4 core heavy duty LC radiator and never had satisfactory results. Like I mentioned before, the LC radiator is engineered by Toyota to cool a straight six motor (which it will do with no probs) NOT a V8. Some people will run the LC radiator, but I would be willing to bet with not as good results as an oversized aluminum radiator. With my LC radiator, I would be pushing 230 degrees pulling grades (Ice House road to the Rubicon) and 210-215 on the freeway. For me, that was to close to overheating.
Cooling is based on volume and airflow. If you have plenty of airflow and not enough cooling capacity you will not have satisfactory results. The aluminum radiator I installed is a two core, most aluminum radiators are not larger than a 2 core. Any two core oversized aluminum will have no problems cooling a V8 with 300-350 HP. If you go past a two core you are looking into the $700-$900 price range. My 28 x 19 x 2 3/4" oversized was $169.00 from Summit racing, $40 cheaper than a 4 core LC radiator.
I have to admit, I am a little baffled why someone would run a 4 core cruiser radiator for more $$$ and less performance? Other than some minor fabricating, it is a fairly easy installation. And the LC has plenty of room under the hood to accomodate some great oversized radiators. It sounds like you are getting ready to invest some good $$$ in a vortec motor, I would not bother risking damaging your motor with the LC radiator.
Just my .02 cents, take it for what its worth :) Not trying to discredit Poser, this is just my personal experiences.
Good luck with your new V8.
Thanks to everyone for all the thoughtful input. Sounds like I could probably run the 4-row with some margin of safety. However, I think I'm going to err on the side of caution and begin looking into an Aluminum radiator.
Also, I may get tired of our 100F days and add A.C. someday. It would be a pain to re-do the cooling system at that time.
FWIW I've got a single core aluminum radiator with 2 electric fans and the belt driven fan and it stays at 180*. (SBC 350 5.7L)
EDIT: Right now I'm only running the big fan and it stays at 180*
attachment.php
Here's a great thread on the topic.
Yes, as far as efficiency goes. I just put a Howe 342-24, 19x24x1.5" aluminum crossflow in my 40 and my temp finally stays at the thermostat's stated temp level.
My current thermostat is a 155 degree, which I must have installed a long time ago to try to somehow counter-act the inefficiency of my 79 stock core:rolleyes: Before I installed the Howe the engine would run at about 165-175 degrees. I'm curious to see how it will work in the summer. I used to get up to 230 degrees on 80+ degree days:mad: :mad: :mad: not good
I replaced a four core copper with a two core aluminum on my 454 powered Chevy II and noticed a 10 degree drop in operating temperature too.
But I have found my stock Land Cruiser radiator does a fine job cooling my diesel.
