- Joined
- Feb 16, 2007
- Threads
- 15
- Messages
- 184
- Location
- Ft. Collins, Colorado
- Website
- www.green-logic.net
Here is an Aluminum 26 gallon subtank that will fit the 80 series and can be done under $300.. The tank came from www.rdsaluminum.com and the dimensions are 36 1/2"L x 16 3/8"W x 10 3/8"T and cost $230 shipped it can be used for gas, diesel and veggie oil.. I put a locking fuel door from a Jeep wrangler 97-07 and they can be found in junkyards or ebay for under $50.. We had to cut a hole in the passenger side rear fender and another hole in the underside of the body to run the filler hose and mount the door..
Mounting the tank we decided to support it from the ends with brackets welded to the frame and a tab for the tank to bolt to..I doesn't seem to hang any lower than the factory spare and might even be a littte higher up..When I do a rear tire carrier I will put a skid plate running from the bumper and under the entire tank to protect it from a direct rock shot.. I weighed out all my options for another tank and this way seems to be the best way to go for the $$$..I'm really stoked on how the billet fuel door came out almost looks better than the factory one...
I also needed to use aluminum for my veggie system and it keeps the overall weight down..The tank will not transfer fuel to the stock tank, but will have a secondary fuel system controlled by a switching solenoid......Here's some pics!
