hay my radiator just exploded dose any one make an all aluminum radiator for the 95 fjz 80 or did Toyota build one for a different year or county just looking to up grade this so important part
thanks
thanks
$800!!??!?!? Wow.
I tell ya Landcruiser is like putting the word racing in front of anything, it makes the price go up by two or three fold!
Hell a good aluminum radiator should not cost $800 that's f-ing nuts!
so who knows about this oem 3 core what fits from what 80 i mean 800$ thats as much as my 4in lift
I think the OEM rad is Aluminum (it is in my 97) When I replaced mine I used the 93 3core brass radiator, I got it from Cdan It was ALOT less then Ron Davis Racing rad. Where I live out hear on the edge of the dessert cooling can be an issue. I have not had a single problem with over heating or running hot since I swaped out to the new 93 rad. I have ran it hard thru all weather without any problems.
Dude,
a punctuation or two?
Isn't alum a better heat conductor than brass? Or is it the other way around? Curious as to why the 3 core brass oem unit gets so much press over the ron davis unit...
Copper is a much better conductor than aluminum, the "brass" radiator has copper components, Aluminum radiators are popular with racers because they are much lighter than brass/copper, makes a noticeable difference in a 2000 pound race car.
And in a never ending quest for fleet average fuel efficiency aluminum radiators have become popular with manufacturers also.
in a 6K pound brick shaped SUV with big tires lift and an mild engine, the exact opposite of a race car aluminum radiators has no real advantage.
In 95 the 80 series went on a diet to reduce weight. one of the changes was the radiator was changed from copper/brass to aluminum. if you have a 93-97 you can use either one.
RT, all other things equal I agree about Al vs. Cu as materials and how that applies to radiators, but ,you also have to factor the thicker core, the wider tubes, the number of tubes ....................:
I'm not so sure about your second point. As the mass of an object increases it's surface area to volume ratio decreases.
