Alternator Issue?
Denver, CO
I'm almost certain this is an alternator issue.... On my son's 94 FZJ80 he said it made weird noises on start and had a bunch of lights on on the dash. Upon further inspection the following lights are on:
A/T Oil Temp - Brake - Oil Light - Red Light above the voltage gage
Checked the battery - its at 11.3v
Jumped the truck and disconnected the cables - no charge coming thru and the battery is dropping...
What should I check other than the alternator?
Planning to replace all 3 belts while we are in there.
Thanks for the help!
Chris
Poor connection, at the plug, between the alt and battery, fusible link? If it needs an alt, have had best results with Denso brand, DENSO 2100181.
Alternator could be a cheap fix if all you need are brushes. $22.70 plus your governor's fee.
Swapped out the alternator, good to go. Good learning opportunity for the kid. If we had time to spare we would have gone the rebuild route.
Side note - is there a method other than unhooking the radiator to get that darn thing out?
Chris
