May want to flip that top plate over?Also, the plates are unique, stamped L and R.
Welded it in instead.
Only kidding.
Took it off an painted it 1st.
By my math, that's only 16.....unless they take the same on the other end of the truck as well. Then all is forgiven.
As Tools said...
24 between the two 80s. I doubled up the rears as well since they are a little more difficult to get to.
I'm in the very slow process of replacing/rebuilding a lot of parts on my '92. I was building a part list and noticed the damn cushion retainers are more expensive than the shocks! I need to buy these because the PO was an idiot and let midas or whoever replace the front shocks before. The left and right sides don't even match in size.
Anyway, this part is just an extra thick, stamped washer.
Does anyone know of a decent replacement part that isn't too expensive?
I tried the google, but that is only helpful if you actually know what to look for.
I might still have some floating around the shop, will check tomorrow.Sheesh, do I just need to make a bunch of these with my next laser cut order? I can these done by the thousands and then cad plate em. Had no idea these were that hard to get. I don't have any spares so if someone has an actual LC one send it over and I'll see about producing a whole bunch.
It isn't that they are herd to get. They are in abundance!
They are just stupidly expensive.
My guess, due to the thickness of the sheet material and the contour stamped in them, it takes a big press and they are probably only produced in Japan. Big equipment + a long boat ride = stupid high cost
Save your time. Make cool things!
Maybe, I just need to see one.
I used the stainless washers in post 5. That was 5-6 months ago. No adverse effects. They fit pretty snug like the factory washers. Just aren't convex (or is it concave?).
