Alignment question
South west utah
So my truck drove nice and straight. Then I wrecked it and now it drifts to the left. I took it to the alignment shop to get it checked. The tech said it was within toyotas specs and didn't think anything needed to be adjusted. He commented on the caster and said if it were his truck he would try adding more caster. What do you guys think. Does my alignment look right? And if it's correct why is my truck pulling left now? Thanks
How and where was your truck in an accident? o you have pics? How severe?
There is a possibility that your track bar is bent and the truck is "crabwalking" and you have to steer to the right to correct it. It's possible that your rear axle is bent.
Many possibilities.
Let us know what happened and we can help diagnose.
I hit another trucks front drivers hub against my drivers hub with my wheel turned hard right. Almost a head on but not quite. The tech said the toe was off a tiny bit, but not enough to matter or effect the steering. Honestly alignment terms confuse me. If the tie rod was bent it would show on the alignment numbers. Same as the frame. If the frame was bent my rear or front would be way off. The autobody shop also put it on a frame rack and said everything was square. I don't think my truck had ever had the castor correction with its ome springs. What kind of caster are most guys trying to achieve when they use different castor correction methods? He explained if the rear axle or anything was bent the thrust angle would be much higher.
Both your front tires have negative toe. That means they are pointing out istead of in. The most common reason for this is a bent tie rod which causes the distance between tbe rear of the ft tires to shorten.
A properly aligned truck would have all reading in the green areas
Would this cause the truck to pull left, what should my caster be?
Caster should be between 2 and 4 degrees.
Thanks, I am going to get some kind of caster correction. And I am going to double check my tie rods and relay rods later today. I will try to get some good pictures.
Sounds to me as if the guy was not really interested in messing with it.
The ONLY readily adjustable parameter is the Toe-In. IF the Camber and/or Caster were out of spec it would involve replacing parts or bushings. He might have been aware of that or might NOT have known how to correct it and simply shied away from the job.
Here's my alignment specs, after my 2.5 heavy emu lift. If that helps at all. Seems to drive fine.
Looks like a caster reading .6° caster.:eek: If you think it drives fine now you are in for a big surprise. The difference between 2° and 4° is day and night with 35" tires. I ran 2° caster for a while and thought is was fine then more to 4°, now I would feel comfortable letting your mom drive my 80 cross country.
I have 31's right now, maybe that's why it's not so bad for me?
Since you had a collision on the LF with your wheels turned hard right, you MAY have twisted your steering sector shaft. That's why I asked. Look at the splines coming out the bottom of the steering gear to see if they look twisted. Insurance SHOULD cover this if you had insurance repair it.
It's possible that it's not ACTUALLY pulling left, but it FEELS like you have to steer to the right to offset an out-of-line steering shaft.
They should have centered the steering gear ("X"/2 lock to lock turns of steering wheel), THEN adjust the drag link to straighten steering wheel, then adjust the wheels to suit.
The Toe-In is currently toe-out and you will feel it grab every seam in the road, pull up the grooves in the road, and dart all over the place. Couple that with the low caster numbers, and it drives like crap.
Even if you bent your tie-rod, they should have adjusted it. BUT, it sounds to me that they're lazy and didn't want to futz with a rusted, frozen tie rod on an old truck. It took me about 4 hours to get my TRE loosened up and new ones installed. Had to use a torch and lots of PB blaster to make it happen.
Also check tire pressure to make sure they are all exactly the same.
I didn't report it during the insurance claim. It would have pushed the repair over the total value. I am going to check this tomorrow. The truck used to steer straight with the wheel straight and now I have to hold the steering wheel slightly to the right to get it to drive straight. Here are some pictures
Correct me if I am reading this wrong, but the specs posted from the fsm show the tolerance for toe at +or - .08 of an inch. My alignment read out shows I am off a 1/16th of an inch or .0625. Which is less than .08 of an inch. Doesn't this mean my toe is within specs?
