how about a bent LCA in the rear.
Which control arm?Local guy JUST dealt with this yesterday. He had a bent control arm after hitting a curb that was covered in water during the rain. Stock everything.
No, but according to the shops I talked to the common weak point is right behind the knuckle ball. The way I narrowed it down by the way is by out of whack camber numbers - the PS differed significantly from the DS side, while both sides matched up on the rear. This didn't improve after a knuckle rebuild, so all signs pointed to a bent housing.Were you able to determine where the axle housing was bent?
I need to re-check my camber after doing a knuckle rebuild, sounds quite similar to my axle unfortunately. Did you get a new housing and transfer all the knuckle castings/hardware, etc over?No, but according to the shops I talked to the common weak point is right behind the knuckle ball. The way I narrowed it down by the way is by out of whack camber numbers - the PS differed significantly from the DS side, while both sides matched up on the rear. This didn't improve after a knuckle rebuild, so all signs pointed to a bent housing.
Yes, and I regeared and did a fresh knuckle rebuild at the same time.Cool
