The 06-07 LC & LX original 82125-35150, 2nd -60650, 3rd -60651.
The 04-05 LC & LX original -35130 I don't see any updates. "May" update when ordering in VIN used. IDK, but I'll ask.
The 2003 LC & LX original -60550. I don't see any updates. "May" update when ordering in VIN used. IDK, but I'll ask.
Toyota has been updating the S.A.I pump filter. I've now seen 3 different designs of the filter. IMHO all 3, will fail. I do think, each newer version will last longer.
I hope this is not case with this transmission wire. But we'll be well service, to keep eye on even this newest 82125-60651 transmission wire. By looking in its housing block and watch for further P/N changes.
Perhaps all A750f original, transmission wire has this capillary issue. One of my hopes with this thread. Is we see if a patterns emerge.
So fax we've:
2- 07LX A750f. With GOO, in the 82125-35150 wire housing block. Shift issues.
1- 08GX A750f. With ATF, in the 82125-60650 wire housing block and much further down stream. O2 issue.
1- 07GX A750f. No ATF, in the 82125-***** wire housing block. P2759 corrected w/new wire -60651
1- 04LX A750f with oxidation in the 82125-35130 wire housing block. Shift issues.
1- 04 4runner A750? (video). AFT, in the 82125-????? wire housing block and much further down stream. O2 issue.
I- 02LX A343f with what appears to be clean Dielectric grease inside wire housing block,. In low miles, clean, with no report of any transmission service. No report of any issues.
Interesting, there was speculation, cause was from the "two temperature sensors" wires:
The 98-02 A343f, has only 4 wires. The one temp sensors, wire just plug onto. Just like wire plug on all solenoid. So far in this thread. No reports of ATF in A343f transmission wire housing block.
The A750f. Has 11 wires. Two of the wires, have temperature sensor built on end. That is to say; they're part of wire end. They fit up in valve body, and seal with O-ring. Each has a hefty bracket retaining them. They obviously have ATF under pressure behind them. I noted, a good amount of fluid, from their port, as I removed them. So they ATF, behind them with static pressure engine off, continues pressure engine/transmission running. The other 9 wires, basically just get slashes or wash-over ATF. They sit well above level of pan. So make sense, temp wire would be the subject to the most and capillary action.
Temperature sensors A/T #1 & A/T #2 (red arrow) of the A750f/e Aisin-Warner 8850 Aisin valve body.
