AJIK Rear Tire Carrier.
VA
After several months of re-design and prototype testing, AJIK is now offering a tire carrier that bolts to the rear OEM cross member for the 80 series Land Cruiser. The carrier will be offered for installation for either the US driver or passenger side. The carrier is designed to accommodate a 35" tire, with an option for a Hi-Lift jack; a 2000lb latch and heavy duty spindle with grease-able zirk fitting are standard option. There will also be several 2" receiver hitch plate options available
As advertised in Vendor section:
https://forum.ih8mud.com/vendor-marketplace/608518-ajik-spare-tire-bolt-carrier.html
Spare Tire Bolt-On Carrier
Standard Options:
1-3/4" Heavy Duty spindle with DOM housing assembly, zerk grease fitting.
Heavy Duty latch
Spring loaded locking pin
Grade 8 hardware for carrier construction
Stainless steel mounting hardware for latch and stops
3- Lug nuts
3/16” upper and ¼” lower arm wall construction
1-1/2" DOM vertical tire carrier tube construction
Tire mount adjustable for selected tire width and offset
35" Tire Capacity (Maximum)
Hi-Lift Mount (For use with Hi-Lift ALL cast or Extreme jack only, not compatible with the cast/steel, other recovery jack systems.)
Antenna Mount
PDF Installation guide
Custom Options:
Powdercoating
1-Year Warranty against craftsmanship, no implied warranty for accessories (spindle or latch) Customer or installer assumes all responsibility for proper installation and managing care to insure proper fit and usage.
Cost: $779. /AJIK webstore. Currently in stock. Expect 7-10 business days turnaround from initial order if out of stock, or if powder coating is a selected option . Shipping is additional.
*PS mounting and blank hitchplate is the only mounting option available.
Well hurry up! I want one with hitch.
Since you have tested both pass and driver sides, which side do you think offers the best visibility?
Looks really nice josh. And knowing you it is well thought out and built stout.
Congrats on a new product that I am sure will sell nicely.
Price/more pics?
AJIK is still working to finalize the carrier. As Josh states more details will follow.
VanGo; [B said:
More product details and how you can order will be released once pricing is finalized[/B].
Nice! Been waiting for this!
Thank you for your patience!
Mounting the carrier to the DS offers the greatest visibility for US vehicles, but has it's own unique set of design issues.
Thank you!
looking forward to more details :popcorn:
this is one thread I want to stay 'tuned' to. :D looks quite promising.:clap:
:cool:
Looks good. Subscribed.
Looks really good, Josh! Looking forward to more info on this.
I think you hit on a real winner here. Obviously price will make a huge difference but your solution rectifies several key issues I was looking at aftermarket bumpers to resolve:
1. Gets the tire out of the way
2. raises the hitch up
I am excited to see what you have come up with!
1ststatecruiser said:
Any gas can option on the other side?
Initially this was a design consideration, but one that is better reserved for a full armored bumper.
Sent from my iPhone using IH8MUD
Thank you. The initial design credit goes to ih8mud member Flank, AJIK has his permission to bring our version to market. Pricing is still to be finalized, however, a consideration throughout the project; most should be pleased with the balance between price and quality that we aimed to achieve. I would like to also add "weight" to your list, the AJIK carrier prototype weighs approximately 75lbs. Thank you for your enthusiasm, as we are equally pleased to offer a needed solution.
Any chance of buying one with a basic arm with no tire carrier welded on? I have a factory tire swing-out on one side, but I'd consider something like this to hold a couple of gas cans on the other side.
