Aisin freewheeling hubs.
Brisbane, Queensland, Australia
hey guys, does anyone know where I can get Aisin Freewheeling hubs from? I was out wheeling the other day and one of mine exploded And the previous owner did the part time conversion so I am unsure as to where I would buy them
Beno
Depending on how you define "wheeling", may want to go back to drive plates, they are significantly stronger than locking hubs.
Especially if you don't have a PT kit in the rig. If the PO just put on hubs for "2WD", the hubs will get destroyed running in 2WD mode for long periods of time.
why is that ..?
They're not designed to be run with the shafts spinning for extended periods of time - it will wear them out prematurely.
Not sure what you are getting at, but don't see how that could be a problem? This is how they work: In the traditional RWD, 2hi mode; the wheels are spinning at ~300rpm at highway speed, the front drive train, axles, etc, are pretty much stopped, so ~300rpm of speed differential. In 4hi (part time without the transfer kit) and the hubs unlocked, the front drive train, axles, etc, are driven at the same speed as the rear, so will very closely match the front wheel speed, the only speed differential will be to prevent bind, make up for cornering, etc. Almost zero speed differential between the hub and birf, or just a few rpm, not significant, would wear much less.
That's a myth. The hub doesn't care if the shaft is turning inside it or not. In reality, running with the cdl engaged and the hubs unlocked would be no different that running a part time converted rig with the cdl engaged and the hubs unlocked. The stub shaft would turn at the same speed as the hub so there would be no wear imparted. Make sense?
Well, if it's a myth it's sure got some other folks convinced it's real. But perhaps their demise wasn't from what they thought it was... but good to know. I'd always imagined some kind of clutch burning up in there - but now that I stop to think about it, it would be worse to have the hubs spinning without the birfs.
I have tens of thousands of aisin hub freewheeling miles in toyotas, including about 3500 on my 80. And intend to have tens of thousands more.
You used to be able to get ADD trucks in the 90s w aisin hubs.
Mud rumorS suck.
While we're talking about Aisin hubs does anyone know of a source for the thin spacer that sits between the hub gear and the ?bottom plate? I've found in a few hubs I've looked at that they will develop a wear step in the spacer.
Mud rumorS suck.
Did you mean AWD trucks?
I mean, I've been accused of having ADD before, but I don't think I've see a truck with ADD before ;)
Oh you've seen 'em.....Just be glad you haven't had to play Doctor on one. It can be annoying.
No, he doesn't. Automatic disconnecting differential, which is a common part-time set up on Toyotas.
Strike two in one thread! I kid, I kid.
No sh!t! That's ok. If I knew it all, I wouldn't be spending so much time reading threads...
I used the Aisin hubs putting in an R151f, the 4runner/truck '85 hubs fit the 91-92 80's with no spacer; and I believe the 93+ need the spacer, if I remember correctly.
