Airbag deployment, NOT
Orange County, NY
Hey guys,
Has anyone with an ARB front bumper had the airbags deploy in an accident? The reason I ask is mine did not active and the truck is totaled. The majority of the damage is the drivers side rear including the rear door, but it did take a big enough hit on the arb to trash it. I remember reading of an airbag compatable arb but that was years after I had mine. I always thought that the sensor was mounted on the body front and would deploy no matter what bumper the vehicle had. I'm I way off thinking this???
Oh, just to ease your minds the cute, little, poor, defenceless, friggin opposum is fine.
On a different note, has anyone brought a vehicle back from the ins company?
Thanks for any info you can send my way
:crybaby:
It's a deacceleration sensor I believe and it is mounted in the center console. So the bumper should not effect it. But sounds like you took a pretty good hit. Not sure why it did not deploy. Is there even one there? Because people remove them and sell them for a lot of $$$.
I bought my 80 back from my insurance co.
Front airbags like you have are designed to deploy in a frontal impact of severity enough to trigger the sensors. It sounds like your heavy damage is to the rear? If so, that explains it as the rough dimensions of the force required to trigger them is an area like a slice of pie in front of you and 15 degrees off to each side. As for the ARB, if it merely crunched in a corner this would not provide enough decelerative Gs to trigger the airbags.
The airbags do not deploy simply because the car is hit somewhere. Only when they'll benefit the occupants.
DougM
Thanks for the replys guys.
Doug, the front hit hard, about 25+ mph dead ctr tree. The arb is trashed. Little hood damage (buckle)because the arb did make contact. It looks like the front frame horns might be bent inward slightly because the arb bent in the middle. This is why I thought the bags would deploy.
The totaled cames from the tree I hit on the rear drivers side door and back.
The reason they totaled mine was the "A" pillars were crushed. Which is an automatic total I hear. Yours might not be as bad. Might be repairable.
If the sensors are in the front, they are usually on the sides...not in the middle (at least on the other passenger cars I have experience with). So if you hit a tree in the middle of the ARB, chances are you had no effect on the sensors.
I thought the sensors were pressure or crush triggered. :popcorn:
I might be wrong here.
I was going to do a search on this very topic soon because I am looking at 80's and 450's and want to put an ARB or similar F&R bumper on it. Was wondering what the effect would be on the airbag function.
Hope you can buy back and fix your 80.
The sensor is accelerometer type, IIRC it’s mounted in the console area, it measures deceleration force on the truck. The stock bumper is soft, the ARB is stronger, so if anything the bags would deploy easier, sooner with the ARB.
What are your injuries like? If you didn't hit the steering wheel and have the seatbelt break your collar bone(among other things) The airbag probably wouldn't have helped. They very well may have been inop, but In this type of wreck you were probably just under the threshold for them to go off.
BTW, Run over every wild animal that jumps in front of you and is smaller than an elk. Too many people die trying to avoid the little furry buggers.
I hope everything turns out fine,
Dan
Sensor is in the center console, under the shifter cover. It takes a specific set of sequences for the air bags to pop. Don't meet those criteria and they won't. In most cases that's a very good thing, the repair tab on the two bags and the sensor (which must be replaced after activating) is over $3,000.
I bought a built 80 (front end hit, air bags popped) back from insurance, paid just under $2k.
I recall air bags are supposed to be replaced after they are 10 years old. Anybody want to look in there owners manual and check. It would be good to know.
Not correct.
The system needs to be inspected after 10 years.
Dan
My injuries are minimum. It stayed up right, no rollover.
I wasn't really looking for the airbags to help, just curious why they didn't active. How is one to know if their bags are servicable. I've been a fireman for many years and have seen many bags deploy with a lot less frontal damage than mine.
Like I said I remember seeing recently an newer ARB airbag compatable bumper. So now I'm thinking mine was not for what reason I have know idea.
Yes I know you should run the animals over, it was just a relex I guess. It was 4:30am in the rain on the way to work.
Thats what I thought. The ARB does not give as much as the oem bumper, so I figured it would deploy sooner.
I'm not sure thats correct, I think if you take a hit on the front anywhere it would deploy. I don't think its sensative to certain points of the bumper only.
someone I knew was in a head-on collision w/ another moving car. He tried to pass in a single lane road (55mph area) so I don't know the relative speeds
but I would guess he was around 40mph, other car 35mph(complete guess- just thinking other car at speed limit/hitting brakes. He was over the speed limit trying to pass/hit brakes or accelerate-don't know what he did.)
He was driving a brand new Cadillac STS (I mean brand new corporate car). Airbags did not go off at all.
The sensors must be very specific in the type of inertia to trigger the airbag.
How hurt was the guy afterwards?
he was fine, i think he was more embarassed 'cause everyone goofed on his (lack of) driving skills. Plus, it was a corporate car so I think he had to be the manager's biotch for awhile. haha
they were all surprised the airbags didn't deploy.
