Air Vent Controller or Motor
Gilbert, Az
Needing advice/help. Maybe I am not searching the correct terms, but what my problem is, is that whatever I push (Heat, Vent, Defrost) all I get is air blowing out my front vents, nothing to the floor nor can I get it to go to defrost. Is the vent door controller using a vacuum controller or an electrical motor and where is it located. Thanks.
Anybody have any idea? Where is the control valve/flapper that send the air to the defrost vents, or front vents or floor vents? Is it electric or vacuum controlled and is it hard to replace?
Bump, anybody? Is Cruiser Dan around?
Thanks, found him and PM'd him. So nobody has had this issue but me huh. Guess once I get it fixed I won't have the issue anymore. I will post what I find and what the corrective action was.
OK, just to update and close this thread. My issue was the Vent Actuator Motor that is located right above the Gas pedal to the right. It is held on by 3 screws and then the 8 pin (or so) connector. It controls the air from Defrost to Vent to Heater Vent floor. Small electric motor about the size of a cigarette package. Time to remove and replace about 20 minutes, but if you bend good to get under the dash you can do it a lot faster. Had a picture of it but cannot find it now and I already deleted it off my phone. If I find it I will post a pic.
You might list what year truck you are working on. I am assuming it is a 94. My 92 is doing the same thing. I wonder if it is the same?
Sent from my iPhone using IH8MUD
You are correct in that mine is a 1994 LC. If you can tell the slight difference in the Recirculating and Fresh air, that motor is a different one, and hence should not be a power issue. Easy check would be to take out the 3 screws holding this one, keep it plugged in and let it hang, when you press defrost, vent, heat, you should see the actuator arm move, if not, then you probable have a bad motor. In my case, all the other buttons on the dash worked, only the Vent would always be blowing air out.
On another quick note, I thought in my research I read that only the middle vents change from vent to defrost to floor and that the side vents always blow. I will say that I find that to be true, my side vents blow no matter what setting, but now I do have defrost and can vent it to floor and middle vents stop blowing. I got my new motor from someone parting out their LC here on the boards, otherwise I think CruiserDan said this motor was like $127 (sorry, already deleted his PM that had the part number and price).
I seem to be having the same problem. I'm stuck in defrost mode on the 97 I just bought. Did yours have issues with the buttons on the unit? When I press any of the vent selectors it lights up along with the A/C button but as soon as I take my finger off both lights go out. I should also point out that the truck never attempts (at least not noticeably) to change which vents it is blowing out of.
Fat-fingered on my iPhone using IH8MUD
Just a bump to say thank you for following up on this thread!!! I had apparently forgotten to hook this motor back up after I did my heater core. I was dreading having to pull the dash back down in order to find the fix!! Luckily all I had to do was plug in the connector.
THANK YOU
