air soft bb's
Buckley, WA
ok so i got 4000 air soft bb's for my tires they are .12 grams each. is 1000 for each tire enough???
I should add they are 36x12.5 bias ply tires
Go get the .20 gram pellets, and you'll use almost half as many. Somewhere around 10 ounces is about right, and more won't hurt. Use a kitchen scale, and if you don't have one they can be purchased for less than $10 at Wallyworld or similar.
-Spike
I am somewhat mystified by this idea. How does it balance a tire?
You want the BB's to ride on the lightest side of the tire, therebye adding their weight to that side and balancing the tire, right?
Now, what will actually happen is that they will go to the side that is farthest out from the center (on the inside of the carcass) because of centrifugal force. The question is, why would the side that sticks out the farthest necessarily be the lightest side as well? Couldn't that side be the heaviest (thickest rubber) in some cases?
It's a nice idea, but is it really valid?
Have I missed something? Thoughts?
This doesnt' seem like it would work.
Won't the beads will accumulate at the locations where the tire is farthest away from the center of spin, not the locations that need additional weight? If this is the case, it would actually make the problem worse. Wouldn't you get essentially this (exagerated scale, of course):
It works. It's an established method for tire balancing in the tractor-trailer arena, where tire performance is considered extremely important, as is cost-effectiveness. Their tires cost as much or more than ours, so they do whatever they have to to extend their life. The military also uses this method, from what I understand. Not necessarily airsoft pellets, but loose internal weights. The science has been proven, although it may not be working in the way you think it is.
-Spike
I second the 10oz for those tires they are on the heavy side IIRC. I run only 6oz in mine and I run them at 80+ smooth with no shimmy. I get a little shimmy at about 40mph but that happened when I had wheel weights and with the previous set of tires also. I rotate mine every 3,000. You will know when to have them rotated when they start feeling out of balance and you get steering wheel shimmy. Just do it!:D
-Spike
Dunno which miltary you are referencing, but I can tell you that nothing in a Marine Corps motor pool(tactical vehicles) has weights or BBs or anything else in it other than a run flat device. As a matter of fact, we don't even balance our tires..........
Saw a quote from, I believe, an Army seargent about pulling the tires off a Hummer and finding the rust power residue from what had once been steel shot. He posted pics. It was on some random forum I found when researching the free weight balance method. He made it sound as if it was a regular practice, but it may have been only in his motor pool or something.
-Spike
Yeah, that's what I mean! It just doesn't add up. Look at tech_dog's picture and think about it!
I'm looking for the explaination that DOES pass the freshman physics test, 'cause I have pretty sensitive BS meter and the needle is banging over to one side pretty hard on this one.
But, I could be wrong. Someone show me how. If there really is proven science behind this, then I'm pretty sure I can follow the arguments. It's not quantum physics after all.
Well, I dunno Josh. I don't think the fact that you put the BB's in your tires proves that it actually helped balance them. I mean, maybe it was just close to a net zero, and you didn't see anything bad happen. Got anything objective or even subjective, like a personal observation before/after?
Instead of asking us to prove it, how about Googling the concept and perhaps you'll find some answers- either pro or con. 'Mud isn't the only place for information on the Internet. That's how I educated myself, and I was skeptical as well.
-Spike
You may be able to find some related science and physics from here.
