Air locker or what?
Alabama
I’m about to pull the trigger on a locker for my rear axle. I’ve had airlockers in my jeeps for decades and have no complaints. But I’ve never had one in an axle with a drop-out 3rd member and wondering what (if any) install problems or any other problems I may encounter.
‘94 LandCruiser, BTW and thanks for your input!
Here’s a pic so y’all can visualize what I’m dealing with.
Love the Marty McFly wheels. My red FJ60 came with the same ones (I quickly swapped them out, lol).
I would honestly go with a lunchbox locker (lockright or aussie) for the rear, as it's cheap, reliable and effective. If you lock the front, then definitely get a selectable locker.
A friend suggested using the innards of a 14 bolt Detroit locker. He said it slides right in the carrier replacing the spider gears. My concern is/was I’m a firm believer in driving open diff as much as possible. Easier on the driveline. Plus, with full time 4x4 I figured it was smoother on road.
I love those wheels! Not for the looks, of course. But they’re only 7” wide! Tall and skinny tires are where it’s at! Those skinny 36” tires tuck into those fender wells with a stock lift with no problems! Stock and fatigued lift!
Uh wut
i have both ARB lockers, install is straight forward, the blue airline came with the kit i have replaced with SS braided lines and never a problem with leakage.
Agree. Another option: Amazon.com: Spartan locker for Toyota 9.5" Landcruiser with 30 spline axles, includes heavy-duty cross pin shaft: Automotive
... My concern is/was I’m a firm believer in driving open diff as much as possible. Easier on the driveline. Plus, with full time 4x4 I figured it was smoother on road.
Full time actually makes it almost transparent, espicially on the road, just a slight click when making tight turns, like into parking spots.
Yes. He said it works.
IIRC, it was the 12 bolt stuff that kinda works, was done back in the day on FJ40, etc? Now what is the point in making other stuff work, when the correct parts are available?
Your friend is wrong or you misheard him. 12 bolt =/= 14 bolt
The 12-bolt mini spool works if you sand down the sides of the blocks or something like that. The point in that would be if you wanted a spool for a 9.5" diff for about $70.
I guess a 12-bolt lunchbox would work in the same manner, but lunchbox lockers are available for 9.5" Cruiser diffs.
I went with the Harrop for the rear. Zuk set mine up. Install was painless. No air lines to set up. Used it a lot last summer. Best money I've spent on the cruiser. Difference in capability is night and day.
^^What he said. Can't be beat. Cruiser Brothers imports.
