Air Lift ~ CACOS
Tornado Alley.
Anybody build a CACOS for their Air Lift?
(Thats a Cheap Ass Cabin Operated System, for those who were wondering.)
I bought the Air Lift bags to use when I load my vehicle down with tools or sand etc.
I'm rather partial to the idea of pushing a button and having it inflate instead of doing it manually.
I love the idea of using a York Compressor, but imagine I will end up doing something easier (12v dc compressor).
I have an old cheesy one that I dismantled (fits in your hand - sort of) that I thought about using. However they have one at Harbor Freight on sale for $50+/- that says it is high air flow. It claims to put our 1.35 cfm at 40 psi or 1.05 cfm at 90 psi.
I don't know what that means ~ is that high or low? How long would it take to air up a tire with that much?
Moreover, what do I need for the CACOS, Air Lift, and OBA?
I think I need:
A switch to inflate/deflate
Maybe one for the back as well
A gauge - I'd prefer a digital one that I can incorporate into the cabin that looks stock.
Air Tank - I've got 2 fire extinguishers that i'm thinking of using
Gauge sending unit
on/off switch for compressor
air line - I've got the cheesy stuff that came from airlift
air bags - Got 'em.
AND . . . can I have 100 lbs of compression in the airtanks to use for tires, or an impact, etc., and also only have 5-25 lbs in the bags?
Any thoughts would be appreciated!
Not tryin to rain on your parade or anything, but they make several different style kits that will probably end up being cheaper and easier than your CACOS. I personally like the automatic, non contact system- everything included ~$250.
But sometimes making your own is more fun!
I don't mind paying for it, but sometimes you pay a lot and end up with sh!t. I'm ignorant about all this stuff, but have always wanted to have OBA, so I'm trying to decide what to do.
I think OBA is pretty cool to have and you've got 2 main choices:
Engine driven - or - Electric
Use the search feature, there are plenty of threads on each.
Both have thier pros and cons; you decide what works best for you. Either way, I would recommend a storage tank of some sort (really helps when airing up tires).
For your CACOS the sky's the limit. From simple manual control and seat of the pants leveling to fully automatic front to rear and side to side height control. You decide how simple or deluxe you want to go.
Good luck!
I have a set of bags with the valves mounted behind the fuel filler door....
I have an OBA on the roof and only air up when hauling a heavy load on the trailer...
Takes about a minute to do, so I didn't really see the need to install a cabin operated system and overcomplicate things....
That being said, these bags run on such low pressure that a bicycle pump would probably be sufficient :doh:
Ok. Well I think I'll go with electric first because of ease of installation. I've got 2 fairly large fire extinguishers that I'm going to use for a reservoir. Maybe I'll put some sort of push button next to a gauge in the back.
Push the button and voila!
