air compressor?
LOS ANGELES
Website
www.destechservices.com
I saw a 2 gallon air compressor at pez-moys today. Cost about 60 dollars. I asked the clerk if That was one of those cheapo ones... He proceded to point at the name... Coleman. He also mentioned that these where the ones I neede if I wanted to run air tools. Soooooo.. My question is... Why isn't anyone using these in there 80's? This one was lighter than expected and I was no bigger than those pre-filled air tanks some use. Again, I would like to know before I buy one of these. Oh and these would make filling up an air matress a whole lot easyer/faster.:cool:
:cheers:
The only one of these I saw with a 2 gallon tank was an AC compressor... Not impossible to do with an inverter, but not overly convenient. It was also limited to 100psi in the tank... If it is the same one, I'd be very skeptical about running much for air tools on it.
Which model is it? Maybe I was looking at the wrong one?
Coleman isn't a well known compressor company, probably 120v AC, and then you have to find a place for it. A MV50/MF1050/Tsunami is $50 from costco, does a good job for airing up, and doesn't take up much space.
An on-board air (OBA) system is comprised of many parts. You will need the air compressor, a tank, and the associated plumbing and electrical wiring. Typical installations are fairly complex with F&R quick connects, in-cabin switches and gauges, etc.
I don't know about that $60 system but I can tell you that an OBA system with a 3/4hp 12v electric air compressor with a 6 gallon air tank is "adequate"; meaning that it will do a so-so job for airing up 35" tyres or running air tools for short periods of time. This OBA system (~$500) will NOT keep up with a CO2 tank or an engine driven York.
For occasional use to air up your tyres after wheeling, the MV-50 (~$50) style air compressors (no tank) work very well.
There have been several good OBA threads over in the "Outfitting" section. I'm not sure where those threads were moved after they split Outfitting into different forums. You should be able to search and find them.
A $60 system will work well for your air mattress. :D
-B-
I like my solution.
https://forum.ih8mud.com/showthread.php?t=136517&highlight=extremeaire+craftsman
Not cheap, not as high flow as a York, but it was fun to build anyway. The Craftsman side was cheap. ExtremeAir... They're proud of their stuff.
The real lesson from my exercise is that it is cheaper to buy a whole unit and chuck the unwanted parts than it is to buy the components individually.
Fun stuff.
