Air Bag Suspension
Ladner, BC, Canada
Website
www.lentelconstruction.com
Has anyone here used air bag suspension on an 80? Can the air bags work with a lift? Just pondering some ideas as the original suspension is getting tired.
Yes and yes
Honestly though, IMO air bags are designed for a reason and that is to help the rear end sag issue when towing a heavy load, not to correct a worn out suspension. Air bags will only mask some of the issues you experience with worn out components. I assume you plan to replace the suspension components and possibly utilize air bags for towing?
I haven't done this but I did read up some when I was considering my options. The consensus I came to after reading the threads here on MUD (search the 80s section for "air bags") was that they work well but on a rig that is going to see off road use you are better off addressing the rear sag issue with an appropriate spring setup as the air bags aren't really designed to stand up to the abuse of off road use. For me that meant OME heavies all around vs OME mediums in the rear and air bags to help level the rig out when I tow.
HTH
Vanny, do a search on Airlift and you'll find plenty of info. Both IdahoDoug and I use Airlift bags to name two. I'm running 2.5" OME heavies all around with air bags in the rear coils for towing.
X2, did many for my customers and that was the advice, bags only for leveling the cruiser when towing but the coils must be in good shape either on stock or lifted and bags MUST have separate filling valve or dual compressor.
You should be cautious if you do extreme off road driving because branchs and debris could puncture the bags or break the filling hoses.
I put in air bags on all 4 corners on a stock worn out suspension a couple years ago, two fronts tied and two rears tied. Yes, it can be used with a suspension lift. Yes, it does help a worn out suspension. IME, you have about 2in adjustability with bags, and their biggest benefit is in towing. I found spending time adjusting both front and rear pressures, is the difference between a relaxed tow and a less relaxed tow. IME, the front pressure adj really helps when using load equalizer bars. The rear bags are an off-the-shelf stock item, the fronts require mods and measures. I did a write-up of my install a couple years ago.
HTH
Scott J
94 FZJ80 Supercharged
I've never heard of the bags in the front as well. Interesting. Would probably help with the weight of the ARB, M1200 winch, dual batteries, etc. even with OME 2.5" heavies. Was it just the worn suspension that prompted that? You have a link to your write up?
May be in the Land Cruiser 80´s but as I recall it was quite common in the older full size Blazers, Broncos and Ramchargers which were used with snow plow attachments for winter season and is were I saw them several years ago when vacationing.
I live in the tropic with zero snow and was aware !!!
NO PUN INTENDED LOL
I have seen many setups where coils are replaced with airbags. Not used in conjuction with them. I don't see why they couldn't hold up to the riggors of off-roading because they are used on the Dakar rally semi's. They also offer awsome adjustability, and a very cush ride. Imagine being able to raise your rig another 2-4 inches for a very deep short water crossing (not recomended for driving longer distnces because of caster change in such an instance) but for a brief moment it would be cool.
Reading this thread I thought if you can set something like the Rancho compresor to adjust the air bags ? ( one line for front and other one for the rear in case that you have 'em in both ends )
I did a quick search, couldn't find the write-up, should be sometime around the end of '05. I was looking to put a winch in my TJM, and wanted to have the ability to put the rake angle of the truck back to stock. I don't really play much with the front unless using the load equalizer bars on the tandem trailer. I just use a set psi to compensate for the TJM.
I find airbags are a great addition to the 80 arsenal, and see their benefit even if using EMU suspensions. I do a lot of trailering, and am a big fan of making sure that the ball height is exactly trailer level, airbags are the best way for that. Any additional weight on the front end will benefit from airbags in static ride height, pitch, dive and roll.
Scott J
airbags x 4
Scott J
airbags x 4
Here you go Scott
https://forum.ih8mud.com/80-series-tech/52803-fzj80-f-r-airbag-install-procedure-long.html
Thanks for that find Ken! One of my first 80 mods almost 100k ago...
If I was to do that front airbag procedure again, I'd probably go with the next size taller bag in the front to give more adjustability in actual height. The setup I used does a good job of tightening the front, but doesn't have the full 2+in of adj the rear does. BTW, the original 2 zip ties I used to locate the spacers in the front are still intact.
Scott J
Airbags x 4
It's has been widely documented and proved that filling both rear or front bags with the same compressor / filling valve ( using a T coupler) is not good for off-roading and even hard cornering because it forces to more body inclination since both bags are coupled through a T fitting so one bag empty and the oposite side fill.
The safest way is using separate fillers through each of the bags either in the rear and front. I know it sounds as a complicated setup but unfortunately this is the only way to do it.
A good motorhome resorts to independent controlled 4 wheel bags to level it when it's parked on uneven surfaces.
We did several bag installation's over the years to our customers 80's who needed to town horse, boat or utility trailers and in all of them we did the separate filling way with dual compressors for the expensive setups and dual valve fillers for the lower budget.
And none of our customers had any problem cornering or 4 wheeling. When you are driving close to a gorge on a very narrow pass, any cruiser tilt to the wrong side could mean a disaster specially if you carry a roof tent or roof rack with heavy items on it.
It's up to your common sense if a bag set ends as a blessing or a curse.
Good advice .. ...
Anycase I thought you can run the setup with check valvles that don't allow the aire come out of the bag instead off you do manually .. the only way to adjust it's to fill the bags ..
Thinking a little more, something like a pressure switch could do the job too, you add more pressure and is you go over that you need, releas all pressure and fill again to your desired pressure.
