ahh front axle
Alum Rock,CA
so this moring I noticed two grease spots underneath my left side front axle. I got under and seems to me like too much grease in there. Now is it time for a front axle rebuild or did the previous owner went grease crazy on the joints.... :bang:
Thats the soupd that happens when the inner axle seal fails.
A full rebuild is required.
Good time to do the Rotors and upgrade to 100 series pads
dang..thats what I thought, Now the big question is I've planned a 1500 mile round trip in 2 weeks. Should I have the axle rebuilt before I drive the 1500 miles or should I wait until I get back...? How much will it cost me to have this job done at a shop..?
Extension 8, cruiserdan. Tell him what you are doing and he will tell you what you need
Or any Toyota Dealer for that matter. You will get a good discount from Dan
Where can you get all this parts from???
Tons of places, most people here use Dan, including myself
Some viable alts are marlins kit for the axle
then you can use brembo blanks for the rotors and pbr pads, that's the cheaper route but it is questionable which is better
personally i'd do it before the trip. Have this done at a shop with all parts and labor.... no idea maybe $1000 or more. There is some people on here that have taken it to a shop but it really isn't that hard, just time consuming the first time, to do it yourself and you save a butt load of money in the process.
it took me around eight hours my first time, and that was in a parking lot with no garage. The hardest part is cleaning yourself up after the mess, but it is fairly simple. Oh and I would definitely change it out before the trip.
Birf Soup!!!
Time to rebuild. Parts from Cdan as mentioned. While all Toyota dealers can get you the parts, they will not have them in stock and you will have to try to explain everything you need. Cdan will spit it out from memory and you will have the parts you need.
Then you need a 54MM hub socket, big brass drift and two big boxes of shop towels. A third hand is helpful as well. 5 gallon gucket and parts cleaner or better yet a real parts washer.
awesome thanks for the info fellas, I m getting down and dirty in the garage. So now that i will be getting new rotors and pads for the front will 100 series pads work on the rear or just the front...? As for the rotors what doid you guys use...? OEM..? Brembo..??
I used OEM Rotors. 100 series only work on the front
That thing is a nasty mess and is way over-due for attention. I would not drive it any significant distance until the axle has been serviced. Do a complete job and use OEM parts from the supplier of your choice.
I would be happy to assist if you wish.
I have to agree. These pictures are a bad problem getting ready to happpen. Fix it before you wreck the birfs, which are very spendy even from a trusted source like Cruiserdan.
Also check the FAQ on this rebuild - Romer and others have posted pictures, detailed instructions, materials needed, etc and have the FSM on hand too.
I know this since our 450 needs the same service in the next couple of weeks!
Good luck! :D
Yes. Time for rebuild.
Question on 100 series pads:
Why are they an "upgrade"? Do they stop better? If so, that means they have more metal in the pad, right? That means that your rotor will wear faster, right?
The 80 pads stop the truck just fine, imo.
Bigger and last a lot longer.
I just finished mine this past weekend. I have not done it before, and it wasn't that hard. Like others said, just a lot of cleaning. I got the parts from Cdan. And I would add to the rest, rebuild it before taking the trip.
100 pads don't stop any better, but they last longer and throw a lot less dust than the 80 pads.
i am in the process of redoing my front axle as well. I bought the whole kit from Cdan. I think the full kit from him was around 200$ I kind of like the idea of using all OEM stuff on repairs and maintenance.
Jon.
