I need some help. I bought a LX470 and put an ARB combo bar on which is about 275lbs or so. I flushed out the AHC fluid using the @PADDO method. I shortened the front sensors all of the way but did not cut them and I moved the rear up all of the way. I added 30mm spacers to the rear. So far so good. When I hooked up tech stream, my initial front pressure was 11.0 and the rear was 7.8, whoa. So I gave the torsion bars 8 turns and got them down a few points each. So then I gave her 13 more turns each which bottomed the bolts out. The pressures are now 6.7 for the front and 6.3 for the rear. Am I ok now? Even with the bars cranked all of the way? Thank You
Ya its fine from my understanding. If you need more torision you can reindex the torision bars.
. After I did the AHC lift, the front sensors are FL -.3 and FR 0 with both joints moved to the top and shortened. Would that have anything to do with why the truck sits 1/2" lower from one side to the other? Should I adjust them to be equal?
