Advanced timing and head gasket problems
Morgan Hill Ca.
I advanced my timing from the stock 3 degrees to 6 degrees for a little more power, It worked. I was wondering if this might put additional pressure on the head gasket. My 1993 LC has 198,000 and runs great, I know head gaskets are a failure point on the 80 series and I don't want to do anything that would worsen this.
I don’t think advanced timing is going to cause your head gasket to spontaneously combust. If it goes it’s because it’s 26 years old. I don’t think any gasket that lasts that long and for 200,000 plus miles is a failure point but that’s my opinion. I would get a Blackstone report on your oil to see if there is any coolant getting into the oil. I did this on my 93 and it was clean. The other option to test the head gasket is the coolant test kit that changes color if there is oil in the coolant.
The timing advance is on my to do list. Did you notice a big improvement?
Ya, was it a noticeable improvement?
I just did this too about a week or so ago. I actually probably landed at around 8*. Noticeable improvement in response and power, zero concerns for added headgasket stress.
There was definitely an improvement in acceleration, it was like the truck lost 600lbs. There has to be a down side too doing this or they would have done it at the factory, right? I understand the increased possibility of knocking but not with 3 to 6 degrees, the knock sensor can easily handle that. Maybe lower MPG's or higher emissions? Any thoughts?
Advancing and retarding timing is pretty common when tuning force induction cars, and that is how you gain big power by pulling timing and trimming fuels. Generally, you gain power by leaning out the AFR, and same goes for normally aspirated motors. The higher the AFR (lean), the more power you gain, and hence hotter the motor runs. Advancing timing a few degree is not going to hurt the motor..just listen for knocking on load, or better yet, put in some high octane fuel....That's why force induction cars from the factory require premium fuel
The only downside is that you have to run decent fuel, (regular 87) which is not an issue for most folks. If anything its one of the few "win win" modifications out there.
If you advance it too far then you will run into major problems with pre ignition, etc...
Great, I run mid grade fuel anyway (89) so I'm good. I used to run (91) for the first 22 years of the LC's life then I got smart and switched to (89). It only took me 22 years to wise up. Pretty good huh!
Thanks to everyone for their comments.
After a few months of driving with the timing advanced I have come to the conclusion that the power has not increased but just been moved around. With definite improved on the low end, it seems to have lost a little on the high end of the RPM range. Does this make any sense at all or am I just imagining it?
