I didn't read the whole thread so that obviously makes me an expert to reply here
I love complexity as much as the next guy, but man O man, fellas seriously? One of the reason why anyone, including the OP, doesn't want to kneel down next to his tire for those extra few minutes is because the OBA system is quite possibly underpowered, and/or under delivering the air given their expectations. I'm kneeling at MOST four min per tire or less, depending on how much I aired down to begin with. I can hear the air going into the valve stems on both SUVs.
The 80 has a York belt driven air comp, the 4runner uses Air Zenith elec air comp. The 80 uses both sliders plus a 1.5g air tank. The 4runner only uses both sliders for storage with the plans of installing two alum 1.5g air tanks that were salvaged from a Land Rover.
Might I suggest any or all of the following for increasing inflation performances?
- get a 100% duty cycle compressor with its own electric pancake cooling fan on top of the head(s)
-run large gauge wires directly from the battery to the air comp. Use quality crimps, not from Amazon! The alum crimps open up over time due to heating/cooling cycles.
-if a relay/solenoid is being used, use a 100amp relay that uses ring terminals (not spade) on the high voltage side.
-keep the air comp cool during inflation duties by popping the hood (if located inside the engine bay)
-install air tanks to help out the air compressor. I use sliders as air tanks on both of my SUVs. Some folks use 2gal air tanks under their vehicles as additional storage capacity.
-fyi both of my systems have 80/105 psi fixed pressure switches. This range is suited for operating ARB air lockers w/o the use of a second step down regulator. Been doing this for 20 years.
-i'm using 3/8" air brake DOT hoses to supply air from the air comp to all storage locations. a 1/4" hose is used for tire inflation duties.
Cheers and happy blowing.
