Remember all... or any of what I told you about the fitment and performance of stock springs, aftermarket springs, modified stock springs, FJ55 springs, FJ45 springs, FJ60 springs, Hodge podge oem/S10 springs, 1980s 3/4 ton suburban reverse arch front springs front and rear, Chevy 1 ton springs (original configuration, leaves added, leaves removed), 54 and 63 inch Chevy springs 53 inch Ford springs and all the other stuff I've bashed together under the '40s?
All of which I have done. And used. And found what worked and didn't work under the conditions and in the environment that we have here.
BTW, you don't have any mates running S10 springs under their '40s. Kevin's has one or two S10 leaves added to OEM '40 packs. Worn out, abused, welded together in the field multiple times (I've done it at least three times when we broke them in the back of beyond) and oft replaced and re-re-configured.
If I am remembering correctly right now, it was the King remote reservoir shock that made Kevin's ride become not brutal, rather that the actual spring packs. In my case it was the Chevy heavy 1 ton 54 inch packs, -1 in front and +2 in back... with the very long and very flat angle shackles.
And my rig has never had that particular kludge that we did under Kevin's (S10 leaves mixed to OEM packs). He may have changed that all up again now that he has the Aqualu frame. But he still does not have "S10 springs".
Anyway...
