I pulled my inspection plug and it looks pretty empty. I can look inside an see the joint. I assume that is not right. I stuck the zip tie in and only got a little on the end. Luckily i dont think i have any clicking at all. I am going to the store to pick up some lube. But i looked in the FSM and it doesn't really say how much to fill each joint. It just says "...repack with lube." Should i put a good bit in there and run it or a while. Then check with a tip tie again? Do we want 3/4 full? I assume you stick the zip tie in until it touches the joint. Then pull it out with just a little of the top o the zip tie not covered in grease.
